how to:cheap short shifter
Old Nov 6, 2003 | 03:40 PM
wwilliam54's Avatar
it WILL run
I tried this recently,worked great
get a shifter from a 2nd gen
there is a joint in between the ball and the **** at the top. The joint is filled with some rubber crap, and the two parts will be hard to pull apart.
when you get them pulled apart, clean off the rubber on the rod that sticks out of the ball.
then get a clamp-on shifter **** (auto zone has em for like 7$) and clamp it on the rod.
put it where the old shifter was, and go
it has about a 1 in throw, feels great
I had to take the shifter suround out tho
Old Nov 6, 2003 | 05:14 PM
REVHED's Avatar
Hunting Skylines
You can do that with the stock shifter as well and you don't need to remove the surround. It's not a proper short shifter as such though. It will shorten the throw a little but it makes it notchy and hard to shift especially if your box is on the way out.
Old Nov 6, 2003 | 11:31 PM
WHY NOT JUST BUY ONE FROM MAZDATRIX THEY'RE LIKE 200 AND THEY'RE REAL SHORT SHIFT KITS?
Old Nov 6, 2003 | 11:33 PM
coldy13's Avatar
Yeah, shutup kid.
Originally posted by LVRX7
THEY'RE LIKE 200
That's why. You can go to a junkyard and grab a stock shifter for $5 and make it a short shifter.
Old Nov 6, 2003 | 11:35 PM
you get what you pay for its like buying jensen speakers over harmon kardons
Old Nov 7, 2003 | 12:10 AM
Gregs's Avatar
200 bucks for a short shifter is ludacris... id rather make my own.....
short shifters are like 30 bucks for civics, why cant they make em that cheap for the rexor
-greg
Old Nov 7, 2003 | 12:55 PM
Yeah the 200 dollar thing is what is holding me back from getting one. I can see 200 dollars being better spent on something else.
Old Nov 7, 2003 | 02:09 PM
wwilliam54's Avatar
it WILL run
with a good greasing it no prop
the one i made is awesome, just a little notchy, but still smooth and really has a short throw with little effort
Old Nov 7, 2003 | 02:10 PM
wwilliam54's Avatar
it WILL run
id rather buy lots of things instead for 200$
gsl rear
header
msilvia
164
Mar 8, 2020 08:00 PM
