Question to the turbo guys
Old Nov 5, 2003 | 11:17 PM
CheddaKing's Avatar
What kind of radiators are you guys using? I checked my stock one, and it was leaking like crazy, so now i need to buy a new one, and was wondering what others have used and have had (or not had) success with. While im on the topic, will FC radiators work? I was hoping to get one i can mount an oil cooler underneath, but if i need to put the oil cooler somewhere else, o well. Any help will be appreciated!
Old Nov 5, 2003 | 11:18 PM
FB II's Avatar
yes you can use an fc one. for the money, that's what i would do. i'm going to keep my stock one for a while unless i notice a major heat issue.
Old Nov 5, 2003 | 11:20 PM
CheddaKing's Avatar
Thanks man, thats all i needed to know
Makenzie71's Avatar
...94% correct.
which is bigger? FC or FB?
Old Nov 5, 2003 | 11:24 PM
coldy13's Avatar
Yeah, shutup kid.
I use the stock one, temp gauge will never go past 1/3 no matter how hard it is run.
Old Nov 6, 2003 | 12:09 AM
FB II's Avatar
WOOOOOT! that's good to hear coldy! hahahha, save myself some $$$
Old Nov 6, 2003 | 01:36 AM
Sudox_E's Avatar
I just put in a new stock radiator and a 16in electric fan, cools great. I would stick with fb radiators, works well, and you know its going to fit without any modifications
Old Nov 6, 2003 | 06:30 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: Question to the turbo guys
FC radiators are realy really big, the one I bought was a 3 row, I got it here locally brand new for like $150. I have a FC radiator here, that im probally gonna throw out. Its anyones if they want it, but Im not screwing with shipping it, too much trouble.
Old Nov 6, 2003 | 09:44 AM
Rotorious7's Avatar
vw rabitt racing radiators. Same inlets/outlets as 1sGen. @ or 3 row available & they are alluminum as well
Old Nov 6, 2003 | 09:55 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
Im using a 22x19x2 alluminum chevy style racing radiator.
car doesnt run yet so I cant tell you temps, but it was a bitch to install.
Old Nov 6, 2003 | 12:07 PM
680RWHP12A's Avatar
new stock ones work fine! spend your $$$ elsewhere
Old Nov 6, 2003 | 06:39 PM
moremazda's Avatar
Gone Race'n
S5/S4 and S3 radiators are all IDENTICAL, in stock form. They all have the same surface area, they all are 2 row brass. The only differance is that the 2nd gens have an inlet and outlet that are intended for use in a "tilt-forward" mounting.
I am running a GSL-SE radiator in my turbo car, and on the way to SS6 in 105deg heat at 80-85 mph the temp NEVER went over 180deg.
Ryan
Old Nov 6, 2003 | 06:56 PM
I wanted to get a upgraded FC radiator, but price was prohibitive.
The chevy one was only $175 but I have to have a fitting added and the bottom inlets angle needs to be modified.
Old Nov 6, 2003 | 07:18 PM
CheddaKing's Avatar
Arent FC ones shorter so the oil cooler can mount to the bottom of them?
Old Nov 7, 2003 | 12:16 AM
CheddaKing's Avatar
Old Nov 7, 2003 | 12:26 AM
Directfreak's Avatar
I am a Jeeper Now.
I believe a stock 79-82 Radiator is a three row (shorty & Fat style, as the oil cooler is mounted directly underneath)
Or it may just be that it is "thick enough" to squeeze a 3 row core into it's frame.
The 84+ FB radiators are all taller and thinner, because of the Bee-hive oil cooler, and SE cars just mount the front mount oil cooler in front of the radiator (which is definately 2 row).
A New stock radiator works fine with high output turbo rotaries.
If you really want more,
go with a Griffin Aluminum Radiator or a custom mounted V8 one.
Old Nov 7, 2003 | 08:36 AM
79-82 is a 2 core, but you can get a 3 core from mazdatrix, they are very nice. I would have kept mine but I could not get the intercooler to fit very well with the stock radiator supports.
Plus I have the bling bling factor of a alluminum radiator
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Clacor
Aug 14, 2015 09:17 AM
bb6guy
Aug 12, 2015 03:29 PM
