4.44 gears need info on where to find
Old Nov 4, 2003 | 02:23 PM
JIMMY54's Avatar
GSL-SE PRO
I was told that those gears can be found on the mazda pickup so I just needed to know the following....
Model
year
2 wheel drive or 4 if that makes a diff?
which axle if it's a 4?
what else would be needed for this swap?
Thanks again!
JIMMY
Old Nov 4, 2003 | 02:31 PM
riddler_pr's Avatar
Yoou may also want to check Kia Sportage, they come, as far as I know, with 3 different gear ratios, 4.44, 4.78 and 5.14...where specifically, dont know for sure...But if you see that many of the pickups are being gutted for these gear ratios, try the kia sportage (korean company for mazda and the rear ends are virtually interchangeable)...
Old Nov 4, 2003 | 02:52 PM
jayroc's Avatar
Yeah, I've heard this too. The front axle of a 87-88 mazda b2200(or 2600, dont remember) 4x4, 5 speed, and this model only, is the one that has the 4.444 gears. At least, I'm pretty sure, anyway.
Actually, grassroots motorsports did an article mentioning this a few months back. Junkyard score!, or something like that.
More info can be found here, too:
http://members.aol.com/solomiata/Drivetrain.html
That should be all you need for the swap. From there, you disassemble both rears and put the old rx7 3rd member back together using the new gears and thats it. Although you might want to measure the..err... the "play" (I forget what it's called) between the gears on the 4x4 axle, and set it accordingly on the new rear.
Old Nov 4, 2003 | 03:00 PM
jayroc's Avatar
Backlash, I believe it's called.
Old Nov 5, 2003 | 07:12 AM
riddler_pr's Avatar
I forgot, you might want to also check out the Mazda MPV's....I am not sure of their ratios, but they are also interchangeable as well...
Queppa
Nov 18, 2024 03:47 AM
The1Sun
Mar 18, 2018 11:08 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
