Starting SCREAMING. Is this bad...or just rotary?
Old Nov 4, 2003 | 01:55 AM
Cody's Avatar
SKELETOR!
Hey people....
This is something that happens intermittantly, and I believe I have seen a post about this, like 2000 years ago....but, I thought I'd just check again, to see if someone knows what it is......and if it means starter replacement time...or what.
Now, like I said, only SOMETIMES, when I turn the key to start the 7, instead of just turning over....the starter, or...what I am assuming is the starter.....will sound like a banshee scream, until I let the key go once the car starts. Now, each time it does it, it still is turning the engine over, and still starts the car....nothing is just free spinning.
Frankly, it amuses me, since it's one more thing to baffle fellow employees at a local auto parts store about the rotary.....but, whats making it do that?
Is the starter dying? Could it mean something is loose? Easy fix?.....what gives?
Old Nov 4, 2003 | 04:47 AM
Aico's Avatar
Ain't it the belts maybe?
Or is it a real metal rattling?
Old Nov 4, 2003 | 04:57 AM
XLR8's Avatar
Silinoid
Old Nov 4, 2003 | 08:55 AM
Mschafe's Avatar
Where did my 7 go?
I've heard it... it's kind of a loud motor-bearing seizing noise, but amazingly the car still starts (i was actually amazed). Ahhh.. just post a sound clip cody.
Old Nov 4, 2003 | 08:57 AM
GavinJuice's Avatar
Leave A Message
That screaming sound is from the starter and it really is no big deal. I have a friend who has an 85 nissan maxima and it does it all the time. Its actually quite funny since people look and stare while we laugh our asses off. To remedy the problem i would just go and buy a new starter, or have someone repair it.
Old Nov 4, 2003 | 10:04 AM
Dcrasta's Avatar
I had an autozone starter that sounded like that. Man it was funny for about a month (starter stopped working). Got a free replacement and the sound went away.
Old Nov 5, 2003 | 11:32 AM
nekky's Avatar
wtb 1g rx7 jdm shiz
It's the brushes in the starter most likely. Exact same thing happened to me this summer. If your car just DOESN'T wanna start one day, get under the car and hit the starter. It'll start right up. DO NOT keep doing this; fix it. One day, the banging just won't work and you'll finally be stuck.
Zac
Old Nov 5, 2003 | 11:41 AM
brianw's Avatar
Mine does the same thing but only when the car is warmed up.
Is this the same problem. I have been assuming that the starter is just going out.
Old Nov 5, 2003 | 11:58 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
your never stuck with a standard gearbox.
push starting is always a option.
Old Nov 5, 2003 | 03:42 PM
Zac
stuck?! what is this stuck you speak of? Ever heard of roll starting?
Old Nov 5, 2003 | 03:53 PM
bliffle's Avatar
I've had nothing but bad luck with rebuilt starters. Instead of buying a rebuilt (which is someone elses broken starter with a hells-angel-rebuild) just rebuild your own good starter. All you need is brushes and bushings, and it's an easy job once the starter is out. And it only costs about ten bucks! Just remember to impregnate the sintered bronze nose bearing with oil (I do it by placing the bushing on a thumb, fillup the bearing with engine oil, and press hard with the other thumb to force it into the bushing interstices).
B
Old Nov 5, 2003 | 03:57 PM
Pedestrian X's Avatar
SpAz!
Zac
Yup, same thing used to happen to my buddies old Subuaru wagon. Would have ot pull out a tire iron and spank the starter a few times. It was an auto, so roll startin it was not an option.
Old Nov 5, 2003 | 04:22 PM
Suparslinc's Avatar
It's Back!
Is it something called the "bendix arm" not engaging correctly?
Old Nov 5, 2003 | 06:53 PM
timmya2's Avatar
theres a banshee in yur engine screaming
Old Nov 7, 2003 | 01:19 AM
RRTEC's Avatar
Rotartist
autozone has lifetime guarantee on the starters, if you don't mind pulling it out to replace it get it there.. screw rebuilding it yourself..... but have them test it beforre you leave the store. it sucks putting it in and realizing the rebuilt is a pile of crap. happened to me three times in the same day!!!!!!!!!
Old Nov 7, 2003 | 07:04 PM
Wankelalltheway's Avatar
You better get it fixed soon or you will ruin the teeth on the flywheel.
cristoDathird
28
May 30, 2019 08:47 PM
The1Sun
Mar 18, 2018 11:08 PM
7aull
1st Gen General Discussion
Aug 14, 2015 10:44 PM
