Quick Question: Efini Y-Pipe Install
Old Oct 2, 2001 | 04:45 PM
R1 POWR's Avatar
I'm currently in the process of trying to install an Efini Y-Pipe, but I'm still trying to take out the original Y-Pipe. Do I need to remove the air pump first??? I really don't want to remove the air pump, but looking at it, I'm not sure if it'll come out without first removing the air pump.
Old Oct 2, 2001 | 05:10 PM
Tim Benton's Avatar
FD title holder since 94
You don't have to remove the air pump for this job. Once you get all the hoses out of the way and the left piece of the stock y pipe off, you can then with some patience, work the right piece out. Its a tight fit, but it will slide out awkwardly. Same goes for the install of the efini y pipe, get the right side in, then the left, then combining them once they are somewhat in place.
Tim Benton
Old Oct 2, 2001 | 05:49 PM
dclin's Avatar
Perpetual Project
Hehe, Tim's right. Then again, I spent so much time trying to wiggle that thing out, it would have been faster to remove the airpump, hehe.
Worried about the belts/tension/et al? Don't be - pretty straight forward to put everything back together again.
Old Oct 3, 2001 | 03:51 PM
R1 POWR's Avatar
thanks tim. i'll try that when i get back to it. right now i'm waiting on some silicon hoses. i figured i'd replace the ones i can get to now, then maybe tackle the rat's nest some other time
dclin,
yes, that's what i was worried about. wasn't there a thread awhile back about belts that were too tight that killed the bearings in the water pump, causing a water pump failure, & an overheat situation. i'm not ready for an engine rebuild yet
thanks guys.
Monsterbox
Jul 29, 2022 10:48 PM
jza80
Dec 6, 2015 05:53 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
