gem acting like a rock
Old Nov 1, 2003 | 10:38 PM
rotairy's Avatar
i got this car and its a good car but for some reason it takes a few trys to get started . once it does get started it idles at 750-800 but wont gas . if any atempt is made to gas it turns lean and trys to kill untill i let off the gas. all vacume and intake lines are bran new. please help im stumped .
Old Nov 1, 2003 | 10:44 PM
Rx7carl's Avatar
Airflow is my life
Is it a stumble/stall/bog? and then picks up and runs? Will it pick up rpm's if you pump the gas? Anymore info you can provide on your problem?
Old Nov 2, 2003 | 07:41 AM
rotairy's Avatar
i guess you could call this a stall. i really cant pump the gas i can only hold the rpms at about 2000 any higher and it goes lean on my air fuel ratio meter and stalls till i let off the gas. thanks for your help.
Old Nov 2, 2003 | 09:08 AM
Rx7carl's Avatar
Airflow is my life
So it will idle smoothly? Sounds like an accelerator pump problem. With the car not running, Remove the cover for the air filter, look down into the carb, then either have someone step on the gas, or open the throttle manually and look for the 2 small streams of fuel that should come from the squirters.
Old Nov 2, 2003 | 12:12 PM
rotairy's Avatar
that sounds like a carb problem this is a fuel injected 1.3 6 port gslse
Old Nov 2, 2003 | 02:53 PM
10,000's Avatar
Check your TPS, do a search and you'll find instructions on how to make a tool to check it. when did the prob start occuring?
Old Nov 2, 2003 | 03:07 PM
Rx7carl's Avatar
Airflow is my life
Hi sorry. Its a good idea to provide that info when you post.
rotairy's Avatar
the car came with a bad fuel pump after i replaced it . its been doing this since the first time i got it started.
Old Nov 2, 2003 | 04:32 PM
BigJim's Avatar
trainwreck
Do the TPS adjustment, i had the exact same problem, did the TPS and now she runs like a beut
Old Nov 2, 2003 | 10:00 PM
coldy13's Avatar
Yeah, shutup kid.
Unbolt the exhaust, sounds like the cat converters are clogged. If you unbolt it and it runs good, just take a bigass screwdriver/pole and a hammer to the insides of all 3 cats
Old Nov 2, 2003 | 10:27 PM
rotairy's Avatar
i really appreciate the help . ive already adjusted the tps although i should check it again . the cats have been taken off in place i have rb header and silencer. if you have any other thoughts please let me know. thanks.
Old Nov 2, 2003 | 10:59 PM
Pedestrian X's Avatar
SpAz!
How about for starters you post the year and model,
-se? What mods you have done to it. That kind of stuff really helps to know when trying to diagnose a problem.
Old Nov 2, 2003 | 11:20 PM
bizarro's Avatar
dunno if this helps but when i got my car the fuel pump was weak, i swapped it with a working pump and it started doing what you described...it also was running rich...i adjusted the r-l screw and all is fine now...maybe the prior owner adjusted that screw to run richer because of the weak pump?...
Old Nov 3, 2003 | 06:55 AM
rotairy's Avatar
sorry about not giving any backround.the car is a 84 1.3 gslse 6 port. i have already replaced all vacume lines and intake manifold gaskets. plugs and wires are decent fuel pump preasure regulator fuel filter are all bran new. the r l adjustment screw hasnt been messed with and still has clay stuffed in it.113k miles are on it and the compression sounds good. i did the throtle body mod and tested for leaks.the only thing i really havent done is adjust or check the timing.
Old Nov 3, 2003 | 09:07 AM
bizarro's Avatar
mine had the black goo on it too...seems like mechanics or dealer mechanics like to put the goo back so we don't mess with it...i've seen it before in the forum...
Old Nov 3, 2003 | 09:17 AM
hotty's Avatar
mine had very familiar symptoms.. It was hard to find the problem, but in the end it was a ground bolt beneath the 4 connectors.(rats nest) i forget what they all are, but one is fuel regulator connector, and hte others deal with the air pump i believe. As I said above, my problems were similar, but when the car was idling fine, if i tapped any of those connectors, it would die. Turns out it was just a loose ground beneath them. Check that, hope it helps.
Old Nov 3, 2003 | 11:45 AM
fatboy7's Avatar
Got Boost?
It really sounds like a TPS problem to me. This engine uses a 2k deceleration fuel cuttoff. If the ecu thinks that the throttle is closed it will cutoff fuel above 2k. That would definately cause it to lean out. If you hold the rpm below 2k, but off idle is it fine?
Old Nov 3, 2003 | 01:05 PM
rotairy's Avatar
i just got finished checking a few things with tha car started and it was able to idle and rev up to about 2000. ive already adjusted the tps with a homade two light three wire device. i questioned the wattage on his lights and he said it doesnt matter . they were small interior accesory lights. i tested the tps w\ a ohm meter it came out ok. do you think i should try to swap it out?
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
Hank
Oct 1, 2015 07:34 AM
