Help!!! Running LEAN.... BOOM
Old Oct 2, 2001 | 01:02 AM
allstyle's Avatar
Unhappy Help!!! Running LEAN.... BOOM
I just swapped my motor out a week ago. I put a brand new 02 sensor in and did the ATF trick. Now when I turn my boost up to 9 lbs, after 5000 rpm my Air/Fuel meter goes into the red, which means I am running super lean. Are my secondaries screwed or do I just need more fuel?
Old Oct 2, 2001 | 02:01 AM
The Ace's Avatar
Greek Power
Into the red ? At WOT ? And you are still running ? Amazing...
Red area is very lean, and is a condition your engine should see ONLY during braking. Not in cruising, NOT DURING WOT. You are obviously running too much boost, and/or your fuel is inadequate (at best... ). Please check above before next WOT...
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
