Dead RPM
Old Oct 28, 2003 | 10:49 PM
RX-187's Avatar
live fast. die fun.
Dead RPM
My RPM reads zero and is not working. What is wrong? How can it be fixed? I am new to the FB so bear with me.
Thanks
Old Oct 28, 2003 | 11:04 PM
coldy13's Avatar
Yeah, shutup kid.
Check to see if you are getting spark on all four plugs. If not then check the trailing ignitor, and it will probably be bad. Replace it and the tach should work again.
Old Oct 28, 2003 | 11:22 PM
RX-187's Avatar
live fast. die fun.
Where is the trailing ignitor located? If I have to replace it, how much? Judging from the idle, it seems to be misfiring.
Old Oct 28, 2003 | 11:30 PM
coldy13's Avatar
Yeah, shutup kid.
There are 2 ignitors, they are the 2 small black boxes on the side of the distributor. Get a Haynes manual, it shows how to test the ignitors, it's just a simple circuit using a battery and a light bulb. If yours is bad, they are always for sale at junkyards, ebay, and on the forum. Usually around $20+shipping. New they are $200+, so you sould defiantly get a used one.
Old Oct 29, 2003 | 02:42 AM
Jeff20B's Avatar
Lapping = Fapping
Start the engine. Your tach ought to start moving after that.
Old Oct 29, 2003 | 09:24 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
and i think the trailing is the 1 on the back side.... not closest to the rad. more towards the tranny
Old Oct 29, 2003 | 09:58 AM
erick1120's Avatar
Yes the trailing ignitor is the one on the back side if you are looking from the drivers side of the car. It is the closest one to the altranator. If you have a haynes manual it shows the diagram of how to test it.
R.O.D
34
Jan 6, 2016 12:09 AM
eplusz
15
Oct 7, 2015 04:04 PM
Thor 18
Sep 28, 2015 07:35 PM
subeone
Sep 24, 2015 09:58 PM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
