hp on a streetport 13bt blowthrough
Old Oct 27, 2003 | 07:55 PM
Gregs's Avatar
How much potential horsepower would a series 5 13bt street ported, stock s5 turbo at 9psi, npr intercooler and 48 ida set up for blowthrogh be pushung?
anyone have a similar setup?
Old Oct 27, 2003 | 08:20 PM
FB II's Avatar
build it, put it on a dyno, and let me know. :P:
Old Oct 27, 2003 | 08:31 PM
Gregs's Avatar
i plan on it next year, ill let you know
lol
Old Oct 27, 2003 | 09:02 PM
Makenzie71's Avatar
...94% correct.
9lbs? 250 to the wheels.
Old Oct 27, 2003 | 09:20 PM
onepointone's Avatar
i say what i want
why would you go blow through? i know if i ever did a setup like that it would be efi. i guess its just a personal thing, but i dont see the need to use a carb when you have all the tunning options with efi.
Old Oct 27, 2003 | 09:25 PM
Makenzie71's Avatar
...94% correct.
carb=easy, cheap, immediate
EFI=can be easy, seldom cheap, requires a bit more tuning.
The EFI vs. Carb debate has been beaten to death. I've taken on the idea that if someone has set goals with not expectations of expanding on to something else then a carbed setp would be fine, fast, and prolly cheaper. If you have intentions of drawing more performance later you'd better go with EFI.
Old Oct 28, 2003 | 12:44 PM
mwatson184's Avatar
holley guy
on my t60-1 I made 312 to the wheels at 10 psi at 6700 rpm on a blowthrough holley 600. On the stock turbo i'm not so sure.
-Marques
1987 T2
11
Apr 1, 2017 11:59 PM
BLUE TII
Sep 26, 2015 10:12 PM
erick31876
Sep 23, 2015 05:16 AM
WANKfactor
Sep 15, 2015 07:45 AM
