Damnit, need help
Old Oct 26, 2003 | 07:13 PM
Godzilla-T78's Avatar
Damnit, need help
Ok, I did the vacumme line simplification everyone told me to do, I do it and now it doesnt run for crap. It will rev to about 2,000rpms and it will start stuttering and poping. It worked fine on and off for about a week then it went to ****. Anyone have any ideas? Im running a pettit ecu, does that have anything to do with it.. Should I just put all those damn things back in?
Old Oct 26, 2003 | 07:45 PM
racer1's Avatar
flying apex seal
Most probably you did something wrong. Pettit ECU has nothing to do with it.
Old Oct 27, 2003 | 08:46 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Re-check to make sure nothing popped off. Check the map sensor line (Black box by firewall) If nothing else try resetting the ECU. Just remove the negative battery cable and stand on the brake pedal for 30 seconds or so... Reconnect and try again.
It's MUCH easier to diagnose these problems with a clean engine bay. If you get around to it maybe sometime over the winter.... remove the UIM and get rid of everything stock under there.. Run all new, fresh lines to the few things you need, and make sure everything else is eliminated.
Good luck.
Old Oct 27, 2003 | 08:53 AM
Well I was told not to leave really anylines under there but I had to because I still have egr or somthing under there.. I removed all the other lines but I left those harnesses hooked up.
Old Oct 27, 2003 | 09:09 AM
ACV is whats still under there.. I will pull the UIM again today and snap a picture.
Old Oct 27, 2003 | 09:21 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Ok. Well, if it ran good for a while after you did the simplification and all of the sudden started acting up.. That leads me to believe that you did everything right, just something popped off... If you snap some pics maybe we can find it.
Old Oct 28, 2003 | 07:42 PM
no, it would mess up even after.. i had to reset ecu everytime i started the car.
Old Oct 29, 2003 | 12:28 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Oops... Double post
Old Oct 29, 2003 | 12:29 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Did you unplug anything, or just do vacuum lines?
Old Oct 29, 2003 | 08:08 AM
Here are pictures of whats under there.. i just took them. I unpluged a few things.. I also routed my coolant line for the throttle body back straight ot the motor... Let me know if theres anything i need to take out or readd.. if you can maybe circle it in paint or somthing?
Picture 1 Picture 2
Old Oct 29, 2003 | 01:49 PM
ttt plz
Old Oct 29, 2003 | 04:23 PM
shawnk's Avatar
Perpetual Rebuilder
Well my hose simplification was alot simpler than yours...any reason your keeping any of that stuff in there? Why not get block off plates and go the whole way?
I am asking seriously - no sarcasim intended. (just wanted to clarify so the thread wouldnt vear off into flameland.)
Shawn
Old Oct 29, 2003 | 05:06 PM
I dunno, where do I get the plates and whatelse needs to come out or go back in?
Old Oct 29, 2003 | 05:07 PM
Old Oct 29, 2003 | 06:08 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
So far I've come up with this:
Still working on it...
Old Oct 29, 2003 | 06:13 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
You can get the plates from rx7store.net.
also, i have the double throttle thing completely unhooked cause I couldnt remember what the hell went to it lol.. other than this you cant see anything that would cause problems?
Old Oct 29, 2003 | 06:17 PM
block off plates will have to wait a lil bit then, i dont have 65bucks to blow on them right now.
Old Oct 29, 2003 | 06:19 PM
im almost positive it has to ahve somthing to do with a check valve or somthing thats not hooked up or not functioning because it makes my ecu freak out..
Old Oct 29, 2003 | 06:35 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Honestly it's hard to tell. I forget what all goes on in that damn rat's nest... It's very simple to diagnose a problem with all that stuff out of there... Although you did simplify the system it's still difficult to figure out what goes where... Even while looking at the hose diagram. I'll keep poking away at it and see if I can come up with anything else..
Old Oct 29, 2003 | 06:44 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Now that I think about it... I believe (And someone correct me if I am wrong) that the ECU you are using is designed to control the stock sequential system. With the T78 installed, all the vacuum lines remained to fool the ECU into thinking nothing was changed. When you simplified the system, you obviously removed some lines. I see the front 2 solenoids have no hoses or plugs on them (Yellow and pink plugs forgive me I forget their function)... Nor do the wastegate and precontrol solenoid plugs (the green and white rectangle plugs) I think that you need to unplug those solenoids with no lines on them and put resistors in them... ( I forget the size) ...I'm not sure about the wastegate and precontrol plugs.. I'll see if I can get someone in here to help me out so I don't lead you in the wrong direction...
Old Oct 29, 2003 | 08:23 PM
thanks so much
Old Oct 29, 2003 | 09:26 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Here's another pic to look at... might help...
Old Oct 29, 2003 | 10:23 PM
so yellow harness needs to be in? anything else? also what about resistors are you talking about?
Old Oct 30, 2003 | 07:42 PM
ttt
rotorsownyou7
11
Feb 10, 2005 11:18 AM
RotaryRevn
Nov 2, 2004 04:06 AM
FB II
14
May 12, 2004 01:15 PM
jpandes
30
Jul 9, 2003 11:09 AM
edpaek
Jan 9, 2002 09:50 AM
