2nd Gen Wg line?
Old Oct 21, 2003 | 12:10 AM
xzyras's Avatar
I don't have 3rd gear
2nd Gen Wg line?
Were would be the best place to run the vacuum line for the WG? I dont know what line would be good to tap for a good soure and what line you should not tap? I have a guage and mbc so I already have the Bov line tapped.
S4
Stock TMIC
To4 turbo (no nipple on housing)
No Twin scroll anymore, Capped off line were switch used to be. What kind of vacuum does that line get?
Blocked off acv and egr. 4 capped off lines? Would any of those work?
Old Oct 21, 2003 | 02:40 PM
xzyras's Avatar
Old Oct 21, 2003 | 02:47 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
wow. a stock topmount and a t04
I dont think they can hold more than 10-13 psi
for best responce drill and tap the compressor housing, and put in a fitting.
Old Oct 21, 2003 | 02:59 PM
xzyras's Avatar
Im only running 10psi. The IC still works pretty well. I guess I'll tap the IC pipe right above it. I just welded it shut where the bov goes. Would that work? You drilled your T04b?
pfsantos
Canadian Forum
Oct 19, 2015 07:04 PM
Don49
Race Car Tech
Sep 3, 2015 05:03 PM
Engine stand ready
Comments and Suggestions Archive
Aug 28, 2015 11:59 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
