FD HID projector conversion is done
Old Oct 19, 2003 | 02:33 AM
J_J's Avatar
J_J
S2K
Old Oct 19, 2003 | 02:57 AM
neofreak's Avatar
accept no imitations™
how much?
Old Oct 19, 2003 | 12:20 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
damn, that's bright. :O
Old Oct 19, 2003 | 12:57 PM
hyper7's Avatar
so when are you coming over to convert mine!
Old Oct 19, 2003 | 01:54 PM
alberto_mg's Avatar
interesting... what are the details of that light?
Old Oct 19, 2003 | 02:07 PM
7racer's Avatar
NICE!!! More info plz
Old Oct 19, 2003 | 04:22 PM
J_J's Avatar
J_J
S2K
We basically installed an HID projector from a Audi TT/3-series (they both use the same projecter) into the 93+ RX7 headlight. The HID equipment we used-ballasts, bulbs, harness, etc- is top-quality equipment made in Germany. It is a very involving process and my friend whom I work with can only do about 2 pairs/month due to time constraints. Price is TBA. I'm going to auction this pair on ebay and go from there.
Old Oct 19, 2003 | 05:01 PM
InsaneGideon's Avatar
Still on 1st engine
Hmm... I haven't looked at my stock housings in a while. Is that a permanent modification?
Old Oct 19, 2003 | 09:21 PM
rockshox's Avatar
wheres the highbeam?
Old Oct 19, 2003 | 09:42 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Very cool!
Old Oct 19, 2003 | 09:45 PM
J_J's Avatar
J_J
S2K
You can always swap them out if you ever want to go back to stock.
Old Oct 19, 2003 | 09:48 PM
J_J's Avatar
J_J
S2K
There's no high-beam. The xenon bulb only powers the low-beam projector.
We are currently working on a bi-xenon retrofit that will allow the projector to switch between high/low beam operation.
Old Oct 19, 2003 | 10:08 PM
RX7 RAGE's Avatar
Top Answer: 1
sweet.......i might be interested if the price is right.
Old Oct 20, 2003 | 01:37 AM
Still on 1st engine
Do you mean I can swap the projectors back to the stock H4's? Or do you mean I can swap the WHOLE housing?
Thanks.
Old Oct 20, 2003 | 02:51 PM
J_J's Avatar
J_J
S2K
You would have to swap out the whole headlamp housing.
Old Oct 20, 2003 | 03:33 PM
SaulV's Avatar
OG
where is the link to the Ebay auction! i want it
Old Oct 20, 2003 | 06:22 PM
J_J's Avatar
J_J
S2K
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2438495533
Old Oct 20, 2003 | 06:32 PM
REFLUX's Avatar
www.v8less.com
can you do this for FC's!??!??!
Old Oct 20, 2003 | 07:01 PM
J_J's Avatar
J_J
S2K
I'll have the details on the FC conversion in about a week. It'll be cheaper, that's for sure, because it'll use a different setup due to the fact that the headlamp is used by other cars as well.
Old Oct 20, 2003 | 07:09 PM
Wankel7's Avatar
Haven't we ALL heard this
Maybe you could see the lamps like you have. But require that the buyer to send you a core.
JAmes
Old Oct 20, 2003 | 09:04 PM
J_J's Avatar
J_J
S2K
No core will be needed for the FC; it'll be a drop-in replacement that will use a new headlight housing.
Old Oct 21, 2003 | 12:11 PM
J_J's Avatar
J_J
S2K
I got a couple of private messages about this setup...
I had HID projectors mounted because they provide a very sharp cutoff and spread light evenly. The beam pattern is very sharp and will not blind oncoming drivers, despite the 3x greater light output of the xenon bulbs. This process is not something new...although I don't think anyone has done this to an FD before. Anyways, it was a time consuming project that I had performed for me because the results are worth it in the end. Whoever ends up with these headlights is going to have something very unique and functional.
Old Oct 21, 2003 | 05:27 PM
SaulV's Avatar
OG
Why is it single beam since the audi TT set comes with hi and low beam?
Old Oct 21, 2003 | 05:45 PM
J_J's Avatar
J_J
S2K
The Audi has a seperate bulb for the high-beam. Its like the RX8: there is one bulb for the low beam and another for high-beam.
There isn't enough room to mount another high beam projector inside the FD housing. We're looking at a bi-xenon retro in the future though. It'll have a motor that will adjust the beam pattern to mimic a high-beam once you flip on your highs.
And to answer a PM... These lights look very similar to the Audi TT and 3-series BMW. Afterall, he mounted the same projector both cars currently use. It also has that color-changing, flicker effect you see as the suspension movement changes the angle of the lights.
Old Oct 24, 2003 | 02:28 PM
choistinks's Avatar
Newbie
That looks nice but it looks like a lot of work. Why not just get an HID kit...I got my for just 350.
