runs fine then not
Old Oct 18, 2003 | 09:47 PM
dole2000's Avatar
Arrow runs fine then not
have a jeckell and hyde thing going with my car. I am on the second carb in 4 months. At times the car run perfect and other it stalls as I go down the freeway.
Most accelerating starts the problelms that cause the backfiring and stalling. I have removed the rats nest and have a racing beat strett pipe. No real cause and effect beyond this. Hot or cold. I can be diriving for 30 miles and all of a sudden it starts up. In time it might go away and other I just manage to limp home.
As a side note. What is average for the number of turns out for the fuel mixture screw?
Old Oct 19, 2003 | 12:02 AM
natew's Avatar
3 turns out is a starting point for the mixture screw.. As far as your stalling problem start with the basics, plugs, wires, air filter, fuel filter and maybe check the timing..
Star with that.. also what kind of 7 do you have?
Old Oct 19, 2003 | 10:35 AM
dole2000's Avatar
I have and 84 GSL that I put and engine for and 83 GSL(12A) into. Haven't been able to get it right. I did put in new plugs, plug wires, fuel filtern and ecen replaced the dist. cap. I haven't done the air filter as it looked pretty good. I've moved the timing around a bit with no clear change. It does idle rough and get get it to be stable under 1000 rpm's.
Old Oct 19, 2003 | 01:59 PM
inittab's Avatar
I read your email
fuel pump problem perhaps?
Old Oct 19, 2003 | 05:55 PM
dole2000's Avatar
I got a second opionon today, the timing is OK and the carb is tuned to where it should be. I do have a leak coming out of the exhaust manifold I believe. Have to address that. I am trying the ATF this evening. The fuel pump will be the next step. Thanks for you help! It ran perfect for about 25 minutes, really strong then it acted up. After we meseed with it a bit it cooled and ran good part of the way home. For some reason I was able to limp home in5th gear at about 1400rmp's
Old Oct 19, 2003 | 06:03 PM
Rx7carl's Avatar
Airflow is my life
Possibly intermittent fuel pump. I had stock pumps go south on me and there was no rhyme or reason for it.
Old Oct 19, 2003 | 09:20 PM
dole2000's Avatar
I put one from the boneyard when I did the motot swap.
Car probaly hasn't seen a new fuel pump since Reagan was in office. Will be alogical next step. Thanks.
Old Oct 19, 2003 | 11:38 PM
racermike's Avatar
aheadau
ignitors? electronics are known to be heat sensitive when marginal. also may be sensitive to rpm (duty cycle).
Queppa
Nov 18, 2024 03:47 AM
sherff
Feb 24, 2019 12:09 PM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
