Quick Kumho question........
Old Oct 8, 2003 | 08:53 AM
MrZUMZUM's Avatar
Below- "Esses" at RA
Even though the Victoracer V700's are marked with an inside and an outside, I'm assuming you can flip them on the rim for more life, right?
These will be used on the track.
Thanks.
David
Old Oct 8, 2003 | 09:06 AM
DamonB's Avatar
That's what most do. Mount them "correctly" and then flip them when the outside is worn. For me there is no need because with the car setup to run on the tires (negative camber) I wear the entire tire pretty evenly.
Old Oct 8, 2003 | 09:27 AM
redrotorR1's Avatar
LS6 Convert
Ditto. I typically flip them once, after the long tread bars start to fade.
Old Oct 8, 2003 | 12:09 PM
MrZUMZUM's Avatar
Thanks...........I guess I better do the negative camber thing............seems like most of you road racers are at about -1.5 to -2 degrees all the way around, from what I gather...........I guess I'll just keep it that way for what limited street driving I do as well............
Tires are flipped...........Sebring here I come..........
Thanks.
David
Old Oct 8, 2003 | 05:39 PM
christaylor's Avatar
There were plenty of good times when Kumho said they were directional, but shipped you 4 lefts...
Toyo's are pretty much the same, too.
Old Oct 8, 2003 | 07:02 PM
Silkworm's Avatar
Has been.. hangin' around
I'm running -2.5, and moving to -3
And as was already said, it's ok to flip.
Old Oct 9, 2003 | 08:38 AM
Rated R1's Avatar
Oji San
Screw the Kumhos. Get some real race tires like Hoosiers.
Old Oct 10, 2003 | 11:50 AM
The Ecsta 700s are designed to be turned inside out, the Victoracers, are not intended to be, and that could result in tread seperation on the V700s according to a Kumho rep I talked to at the track about a year ago. Carl Byck
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
