Coil Over spring rates and lengths for TEIN suspension
Old Oct 7, 2003 | 08:25 PM
mr-s413bt's Avatar
Hey guys.
Ok i am fed up with the springs in my Tein Coil Overs already.
Now the have a helper spring in the top, basically to stop spring rattle and to make the suspension slightly more progressive.
Now i am going to get some custom springs and would like some idea as to what rate and length.
ATM i have 8kg-mm 175mm long with a 80mm long helper spring.
I am thinking of going to a 250mm 220lb spring. Does that sound about right for the front of a Series 4 RX7??
If not any suggestions? I am ordering tomorrow.
Cheers Glenn
Old Oct 7, 2003 | 09:11 PM
Aristo's Avatar
Where can you get custom springs made and how much are they?
I need a pair too..I need a 60mm inner diamater spring, 250mm in length with spring rate of 5.5 kg/mm.....how much are the Eibach ERSs that are made in Australia?
Old Oct 7, 2003 | 11:50 PM
mr-s413bt's Avatar
Hey Dude.
OK i was thinking of getting a pair of 250lb 200mm springs for the front of my FC rx7. at a cost of $275 for the pair.
But not sure on eibach springs
rgordon1979
40
Mar 15, 2022 12:04 PM
