Rebuild
Old Oct 7, 2003 | 04:59 PM
j-spec_wannabe's Avatar
Rotary []D[][\/][]D
Question Rebuild
I know i'm being a post ***** lately, but i need to know where and what exactly do i need for a rebuild. This would be my first rebuild with the help of a friend, but i would just like to know exactly what i would need, i know theres a **** load of seals but what would i have to get. Also if i could see a link to somewhere where i could get all this **** tat would be great.
Old Oct 7, 2003 | 05:18 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
http://www.atkinsrotary.com/
They can let you know exactly what you need and how much. If you can't find a housing in a yard, or from a friend (gsl-se addict said he had one), you're looking @ approximately $1500 to do it all yourself, if you can find the housing somewhere, then the rest should be around $1200.
Brian
Old Oct 7, 2003 | 05:43 PM
gsl-se addict's Avatar
Super Moderator
think Brian is about right on the cost. I just rebuilt my -SE and I needed housings too. I got a set of used rotor housings in good condition from atkins for $200 a piece. You can also try http://www.atlantarx7.com. They sell used rx-7 parts. They have housings for $125 a piece, but I have not bought from them and I am unsure what condition their parts are in. So here is a run down of the things you may need:
Rotor housings ~$125 to $200 a piece used, ~$350 new
possibly a rotor if yours is damaged
hard seal kit (apex seals, springs, etc.) ~$440 or so
soft seal kit ~$100 or so
plus any upgrades you may wish to do, porting, high volume oil pump, upgraded oil pressure regulator, etc. The rebuild process is not very difficult. You should be able to handle it with out many problems. You may also want to consider a 13b swap depending on time, budget, and what you want out of your car in the long term.
Hope this helps.
Kent
Old Oct 7, 2003 | 06:08 PM
Atkins Dan's Avatar
Former Site Sponsor
Wink
j-spec_wannabe give me a call @ 253-848-7776 ask for dan and i can tell you what you need' we also have rebuild videos in stock . our engine kit for a 12-a is 455.00 + shipping for more info call me or have any questions call .
Old Oct 7, 2003 | 09:10 PM
Rotary []D[][\/][]D
Sweet guys thanks so much, actually my friend is giving me his 12a block with everything in it plus the trade of mine because he's rebuilding it anyway. Tell you the truth over this winter we will be rebuilding a rotary for the first time which he is going to put in his Lotus kit car, so if we do need anything i now know what to do!!
dan atkins thanks alot for giving me your number and i will be calling in the future for help. Thanks so much
Vartok
16
Oct 8, 2015 04:49 PM
NickNac113
13
Oct 1, 2015 09:25 PM
musker
Oct 1, 2015 05:58 PM
