Strage start up
Old Sep 29, 2003 | 07:09 AM
mendizabal's Avatar
Strage start up
Hi all, I dont know what can be wrong with my car because when I started cold it goes like common to 3 and I touch the gas pedal and goes all the way down util it dies.
Then I started again a everything is ok. What can be wrong.
Thanks
jose
93 CYM
DP
MP
Exhaust
Pettit ecu
Pettit Stock Mount Intercooler
Greedy Profec B
Walbro Fuel Pump
Greedy Intake
Underdrive Pulley
Old Sep 29, 2003 | 07:31 AM
Mahjik's Avatar
Mr. Links
I've had this happen as well (only twice to be exact). For me it only happens when I've been working on my car for an extended period of time (when I start a few projects, but don't finish them for 2-3 weeks).
Does this happen every time you start your car?
Old Sep 29, 2003 | 07:24 PM
mendizabal's Avatar
No only when the car is cold.
Old Sep 29, 2003 | 08:39 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
This happens to me on occasion when I step on the gas too soon to lower the RPM's or have the car in gear when I start it.
Make sure that the car is in neutral and let it fully spool up before you step on the gas to lower the RPM's. If this doesn't fix it let us know.
Old Sep 29, 2003 | 08:58 PM
BicuspiD's Avatar
Infamous...Butcher...
push in the clutch and start the car with the gearshift lever in first, see if you have the same problem - this will avoid the neccesity to blip the throttle to come down in the rpms..
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
