11 volts to pumps!
Old Sep 28, 2003 | 06:53 PM
mmonaco's Avatar
Part out my Car
11 volts to pumps!
I put 2 warlbors in parallel so to support the extra pull that the pump would pull i ran a 12 guage wire frmo the resistor that is under the master cylindar to the back of the pumps. Th reason behind this is that the pumps arent on all the time and dont always need 12 volts. But anyways i tested that 12 gauges wire i ran and its only getting 11 volts. How can i fix that? and not have the pumps running at full blast all the time? thanks
Marc
Old Sep 28, 2003 | 08:03 PM
lerch32's Avatar
I had the same issue, so this is what I did. I am running my walbro on the stock circut, and running my stock pump directly off the battery, with a switch, and fuse. This way when I need the extra pressure, all I have to do is flip the switch. That gives a full 13.5 to 14 volts when I need it on the stock pump. I just leave it off during normal driving. I mainly use it at the track.
Old Sep 28, 2003 | 08:15 PM
lerch32's Avatar
Old Sep 28, 2003 | 08:19 PM
mmonaco's Avatar
Part out my Car
would it help if i ran a 4 gauges wire? Why am i getting this 1 volt drop?
Old Sep 28, 2003 | 09:18 PM
InsaneGideon's Avatar
Still on 1st engine
Check for voltage drops across the ground wire, fuel pump relay(s), and even the damn fuse. Electrical contact points like relay reeds, switch contacts, and fuse connections can get dirty and/or worn out and become more resistive.
Old Sep 29, 2003 | 06:54 PM
mmonaco's Avatar
Part out my Car
ok will try that! thanks
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
imitek
Oct 18, 2015 03:35 PM
astrum
Sep 7, 2015 11:41 PM
The1Sun
Sep 7, 2015 10:21 PM
