300zx brake upgrade
Old Sep 24, 2003 | 07:38 AM
eyecandy's Avatar
300zx brake upgrade
I was curious if anyone has put the 300zx front and rear brakes calipers on there FD. I have been thinking of doing it for atleast the rear, to upgrade the single floating cailpers to 2 piston..
I want to say there is some Japanese tuning company that uses these brakes, maybe Feed or Pan speed? Can anyone varify this. Or have any info on installation...
Old Sep 24, 2003 | 10:09 AM
DaleClark's Avatar
RX-7 Bad Ass
I seem to remember seeing pics like this - it may have been Skyline calipers, BTW.
Anyhow, there's likely some fabrication involved - ie, creating an adapter bracket. Unless you're quite skilled with machine work and brake systems, I'd leave it be - something goes wrong with the brakes, and you're SOL.
Dale
Old Sep 24, 2003 | 10:22 AM
rynberg's Avatar
Um, sorry but the FD comes with 4-piston front brakes. I seriously doubt the 300ZX brakes are better than the stock FD brakes, or even as good.
Old Sep 24, 2003 | 12:53 PM
DaleClark's Avatar
RX-7 Bad Ass
I know the Skyline GTR has some SERIOUS brakes - they're designed to slow down a rather heavy AWD car. They're Brembo calipers as well.
Again, interesting thought, but I wouldn't want to guinea pig the idea .
Dale
Old Sep 24, 2003 | 01:04 PM
cruiser's Avatar
I know for a fact that stock 300ZX rotors suck. Now... Skyline has better ones, way better
Old Sep 24, 2003 | 03:46 PM
eyecandy's Avatar
Umm the 300zx brakes/rotors are the same as the Skylines.. So i guess they both suck then?
I did alittle more research and I found out that Feed uses 300zx Brakes as upgrades for their FDs..
Thanks anyways guys!
Old Sep 24, 2003 | 04:01 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
Ok, both the 300ZX and the RX-7 have Sumitomo brake calipers, so for the front calipers its pointless to "upgrade", if thats what YOU want to call it, the front calipers on the 7. The rears would work, almost a direct bolt on I heard! I actually thought about it also.
Old Sep 24, 2003 | 06:24 PM
Knifeboy's Avatar
I have upclose pics of an FD in japan with skyline brakes and wheels, so it is definitely do-able.
The thought has crossed my mind but now I can get Porsche (made by brembo I believe) 6-piston calipers for a pretty good price so I'm gonna shoot for those instead. Now I just gotta find out how much work and money is involved.
Jason
Old Sep 24, 2003 | 08:58 PM
eyecandy's Avatar
Yeah I would leave the fronts the same, just change the rears for the extra piston, and need/want to shave off the Nissan on the caliper..
Knifeboy- why don't you ise the 8 piston from the Audi RS6?? hehe
Old Sep 24, 2003 | 09:12 PM
Knifeboy's Avatar
Cuz I don't know anything about them or anyone who can get me those for cheap. The Porsche ones on the other hand I can get pretty cheap. And by cheap I'm talking $400CAN. Besides the 6 piston calipers are pretty big, meaning I'll have to buy some larger (17" or 18") wheels to fit over them.
Jason
Old Sep 25, 2003 | 12:43 AM
turbojeff's Avatar
Do it right, do it once
Guys just so you know, bolting on bigger calipers doesn't always give you any better braking force. There are piston diameters of the master cyl, calipers, etc that all come into play. Bigger isn't better if it isn't engineered.
I don't know why the blanket statement "300ZX rotors suck" was made. Figure the 300ZX weighs in at 3200-3400lbs, the FD weighs 2750-2900 lbs stock for stock. A "sucky" brake rotor on one car might be a good one on another.
I bet those awesome go-kart brakes work for crap on a FD.
Jeff
Old Sep 25, 2003 | 12:59 AM
cruiser's Avatar
Well, my friend has 400hp 300ZX and complains about them.
rynberg's Avatar
Ok, I looked it up.
The 93-96 300ZX used 4-piston iron calipers (not aluminum = heavy) and had 11" rotors up front. The stock FD brakes are aluminum 4-piston calipers with 11.5" rotors. Some upgrade. The rears did use 11.7" rotors with 2-piston iron calipers. This most likely does not represent an increase in performance over the stock FD rears of 11.5" rotors.
BTW, upgrading the rears without upgrading the fronts may result in a braking imbalance. It may actually result in longer stops as the ABS may be made less effective.
Old Sep 25, 2003 | 02:37 AM
suprfast's Avatar
i helped a friend do the brakes on his Z before. they are really beefy in size, but everything felt heavy. if you swap calipers and all then you can even get the little drum brake shoes that are used to hold the rotor(inside of the rotor so they are actually shoes) with the parking brake on. now that would just be cool, not really. i dont think its worth the hassle. if you have to do it, go really big. im sure most of our calipers are just in need of a major rebuild.
question though. if we take off the calipers and take them to a machinest, cant they just make the piston area larger and then we would just find a piston that would work in that area. possibly just have the machinest make something else. it would be a true hybrid brake upgrade.
kris
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
