Difference in NA and TII airpump?
Old Sep 23, 2003 | 11:36 AM
darkwaveboi's Avatar
Need donor car in Fairfax
I cant get the belt on my airpump with it mounted correctly. The pump also hits the stock intake and doesnt have much movement area. Is the Turbo airpump smaller then the na? also can an 88 pump be used on a 91 car?
Old Sep 23, 2003 | 03:30 PM
Icemark's Avatar
it is my understanding that the mounts are slightly different
Old Sep 23, 2003 | 03:35 PM
Fingers's Avatar
The s4 and s5 pumps have different mounts if I recall correctly because the water pump/housing is different.
Old Sep 23, 2003 | 03:38 PM
DaleClark's Avatar
RX-7 Bad Ass
The outlet pipe of the pump is also different - it's angled around on the turbo, and just short and straight out on the NA.
There's also a spacer that goes in on the pivot point for the air pump. It should go on the BACK side of the pivot point, farthest from the pulley. On the other side, that would cause problems with the belt lining up.
Dale
Old Sep 23, 2003 | 09:20 PM
hmm, yeah im having trouble getitng the hose on the back becuase its an NA pump.
dcfc3s...i see what bolt your talking about, i put it behind the hole on the front, but in front of the mount that bolts into the housing (so its inbetween the pivot and the front part of the airpump) its supposed to be on the back part?
when i said the belt wouldnt go on, i meant it was too small....should i just go buy a bigger one for the ghetto rigged airpump
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
mulcryant
Sep 9, 2015 05:24 PM
Ian_D
Sep 6, 2015 10:38 PM
acha3
Sep 6, 2015 08:14 AM
Nosferatu
Sep 5, 2015 02:13 PM
