do s5 gauge clusters work with s4's
Old Sep 22, 2003 | 02:09 PM
mrb63083's Avatar
I've got an 88 turbo II and my tachometer dosn't work. I'm just wanting to get a new gauge cluster but like the look of the s5 ones. I was curious...do the s5 guage clusters plug into the s4 harness on the back?
if so i'll go ahead and get an s5 turbo II gauge cluster.
thanks,
Marshall
Old Sep 22, 2003 | 02:37 PM
nashman69g's Avatar
Boost Addict
they do plug into one another but the actual wiring is different...there is a write up on how to do the conversion--you just need to switch the order of some of the wires!
Hey we have the same name-not many Marshall's around!
Marshall
Old Sep 22, 2003 | 03:14 PM
mrb63083's Avatar
haha yeah. Thanks
Old Sep 22, 2003 | 03:25 PM
Rxmfn7's Avatar
Do a barrel roll!
First, are you sure that your non-working tach is because of a broken instrument cluster? Have you checked the wiring, fuses, etc? 2nd, yes there are a few pins that need swapped. I have a S5 N/A cluster in my S4. Check out this thread I posted a while back..
https://www.rx7club.com/forum/showth...cal+gauge+swap
Also, why not get a S5 N/A gauge cluster? You can have a higher redline indicated (for that future streetport and light flywheel ) and a volt gauge as well. PLus the stock boost gauge is about worthless anyway once you start modding.
Old Sep 22, 2003 | 03:36 PM
mrb63083's Avatar
where are the fuses at on the cluster, i 'll check that. All my other gauges work, it's wierd.
Old Sep 22, 2003 | 03:39 PM
Rxmfn7's Avatar
Do a barrel roll!
Check the fuses that are under the dash by your left knee. One of them is the tach fuse. I was having problems with my power windows once, and was testing them with my portable DC power supply, and accidentally put a little too much voltage through the circuit, and for some reason it blew the tach fuse.. I dont remember exactly which one it is, but its one of them under there.
streetlegal?
Mar 17, 2022 02:46 PM
Heedlessone
288
Sep 16, 2018 07:22 PM
andyvideopro
Aug 20, 2015 10:55 AM
