how to remove and replace rear upper control arm?
Old Sep 22, 2003 | 11:52 AM
ZeroBanger's Avatar
Is there anything really technical about it? Do I need special tools. A general step by step would be nice.
thanks
Old Sep 22, 2003 | 01:13 PM
cewrx7r1's Avatar
Eye In The Sky
1: Get a Mazda maintenance manual.
It tells how and even has pictures.
Normal tools is all that is needed, plus a jack.
Old Sep 22, 2003 | 01:16 PM
ZeroBanger's Avatar
Thanks,
I dont have a manual and prefer not to spend 75 bucks for it.
I'm sure someone has done this and would not mind telling me how, thanks!
Old Sep 22, 2003 | 01:20 PM
If ya don't want to get the FSM, I am sure you can figure it out by looking at the thing. If you can take something apart and put it back together I am sure you will be fine
-Ben
Old Sep 22, 2003 | 01:21 PM
ZeroBanger's Avatar
-Ben
thanks ben, that was insightful. I really appreciate it.
Old Sep 22, 2003 | 01:33 PM
DamonB's Avatar
Originally posted by ZeroBanger
Thanks,
Then take the tire off and look at it yourself It's obvious and not hard.
Old Sep 22, 2003 | 01:35 PM
ZeroBanger's Avatar
Forget it. I asked a ******* question. I help you guys on this ******* forum every ******* chance I get. If you dont want to answer a ******* question then dont.
I'll take the ******* thing off and fix the ******* thing. Thanks for all your ******* help.
Old Sep 22, 2003 | 01:46 PM
Rated R1's Avatar
Oji San
You shouldn't use the same cuss work more than once in the same sentence. Doing so shows a true lack of vocabulary.
Old Sep 22, 2003 | 01:52 PM
DamonB's Avatar
Three of us basically chimed in and said not to worry about it, it isn't hard. We figured you were smart enough to look at it yourself and figure it out.
I guess we were wrong.
Old Sep 22, 2003 | 02:06 PM
DamonB's Avatar
Re: how to remove and replace rear upper control arm?
No.
Do I need special tools?
No.
A general step by step would be nice.?
Jack up car and remove wheel.
Remove lower strut through bolt from upper a-arm.
Remove upper strut mounting nuts and remove strut.
Remove upper mounting bolt from upright.
Remove inner mounting bolt from upper arm.
Remove arm.
Install is the reverse of removal.
Old Sep 22, 2003 | 03:24 PM
BicuspiD's Avatar
Infamous...Butcher...
3rd gen factory service manual
http://www.iluvmyrx7.com/1993_factor...ice_manual.htm
please don't flame Im only trying to help
Old Sep 22, 2003 | 04:42 PM
rynberg's Avatar
Hey David, you can borrow my service manual.
Monsterbox
Jul 29, 2022 10:48 PM
fjwheeler
22
Jan 9, 2022 01:02 PM
GrossPolluter
Aug 15, 2015 10:32 PM
