quick check engine light quesstion
Old Sep 21, 2003 | 05:23 PM
1.3maxhp's Avatar
My check engine light is on so I grounded the ten and my check engine light flashed one long then 5 short, 5 short, 5 short. Is this my o2 sensor or knock sensor? The light stays on all the time. I dont know it the o2 only comes on while driving or not. My o2 sensor is reading .7-.9 volts.
thanks matt
Old Sep 21, 2003 | 06:46 PM
books's Avatar
one long and 5 short...would be 15 which is a code for the O2 sensor..not sure what the remaining 5 short flashes are...if you started out with 5 short flashes that would indicate 05 or knock sensor...the ecu should flash the lowest numbered codes first, then the next lowest and so forth...after the last code is displayed it will repeat all the codes again from lowest to highest....recommend checking again
Old Oct 21, 2003 | 09:06 PM
SWAT81's Avatar
8AN5H33
I'm having the same results on this one, with the long blink in the beginning then 5 short blinks afterwards constantly. The long blink doesn't come back only the 5 short blinks kept on blinking.
Old Aug 21, 2006 | 03:20 AM
wowbogusman's Avatar
FM!!!! FUUUUUGGGIN MAGIC!
my check engine light goes on when i drive the car hard cold...
5 short 5 short.. then thats it
Old Aug 21, 2006 | 09:59 AM
Cgotto6's Avatar
Uhhh....Why are you driving the car hard when its cold?
Old Aug 22, 2006 | 09:04 AM
CantGoStraight's Avatar
What's your point ?
You don't need to worry about codes, just keep driving it hard cold and see where that leads you.
Kyo
Apr 13, 2019 09:24 AM
elfking
Aug 19, 2015 09:48 PM
