clutch won't disengage
Old Sep 21, 2003 | 10:52 AM
newtotherex's Avatar
hey,
yesterday i was driving my car pretty hard redlined it pushed the clutch in to shift from first to second and the clutch pedal just went to the floor and now i can't shift while the car is running and it's hard to shift even when the car is off seems like my clutch is stuck in the engaged position. when i shift it into first when it's off then try to start it the car lurches forward. any ideas what it might be? i was thinking a broken or bent clutch fork but was hoping it's something simple and wouldn't have to drop the tranny not looking forward to that
any advice would be appreciated
Old Sep 21, 2003 | 11:26 AM
Bruce's Avatar
Start off by checking the linkages for the pedle, It might be a slave cylinder issue, but I'm not a huge hydraulic clutch buff
Old Sep 21, 2003 | 02:48 PM
mr_vaughn's Avatar
Chillin
i did the same thing to mine but my clutch disc went and ripped into pieces
now have new racing beat heavy duty sterr clutch
Old Sep 21, 2003 | 03:12 PM
Aaron Cake's Avatar
Engine, Not Motor
Most likely a bad master or slave cylinder. Check for leaks, missing fluid, etc. Try bleeding. If all else fails, replace both cylinders (they're cheap).
Old Sep 21, 2003 | 06:10 PM
mightymouse0x's Avatar
wish my car was faster...
make sure the clutch line hose isnt busted, its on the firewall practically. check and make sure its on tight and not broken
whinin
Mar 30, 2019 07:53 PM
firzen
Sep 15, 2015 12:04 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 9, 2015 08:06 PM
