Fuel Pump opinion
Old Sep 20, 2003 | 11:19 PM
KaiNalu's Avatar
Fuel Pump opinion
I have a '79 12A Street Port which I'm probably gonna Turbo. I need some opinions on what would be the best fuel pump for that setup. Intake is going to be 48 IDA Weber and customer intercooler setup. Thanks in advance, Bob
Old Sep 20, 2003 | 11:28 PM
FB II's Avatar
walbro 255lph
Old Sep 20, 2003 | 11:56 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Mario says to get a Carter pump cause it's the best.
Old Sep 21, 2003 | 01:35 AM
RotorMotorDriver's Avatar
Seven Is Coming
Uh oh...I can feel Mario getting mad already, lol
~T.J.
Old Sep 21, 2003 | 05:10 AM
REVHED's Avatar
Hunting Skylines
You need something that will supply at least the carb base pressure plus whatever boost pressure you'll be running with a bit to spare.
Old Sep 21, 2003 | 08:32 AM
Rx7carl's Avatar
Airflow is my life
Yea he swears by them. And like revhed said, you need to know what boost youll be running so you know what pressure output youll need.
Old Sep 21, 2003 | 01:19 PM
KaiNalu's Avatar
Thanks for the advice guys. Probably gonna be running low boost to start might max out at about 30psi down the road. Should I get something that would accomidate for that now rather than wait? Also who sells these fuel pumps for a decent price?
Old Sep 21, 2003 | 07:59 PM
alien_rx7's Avatar
Interstate Chop Shop CEO
Hey, I like my Carter too. Of course it is definately noisy until the car gets started then I don't notice it as much. However, I don't think my 100lph, 7 psi Carter would flow enough for a turbo setup especially if you'll be moving to 30psi down the road!
Old Sep 21, 2003 | 08:19 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
I have the 7psi Carter too, it's noisy a bit, but a pretty good pump. I use a Dellorto + RB exhaust, on a stockport 12a, but i'm putting a 13B gsl-se engine in it next week.
Max
Old Sep 21, 2003 | 10:04 PM
Sterling's Avatar
30 psi?! Holy Crap!
You had better do more research about a fuel pump than a couple little questions on the forum! At boost, the fuel pump becomes the most important component you have!
...and I was just poking at Mario about the Carter. I doubt it'll do your situation well.
Mario recommend the Mallory pumps.
You better research this one pretty good. You should just focus on getting the system to run the standard 8-14lbs for now, and concider the higher boost later on down the road. But that's just my opinion, and I do NOT have a boosted car.
The advice is more about setting sights to more reasonable, attainable goals, and then making them better when you get there.
-Ya know,...baby steps.
Old Sep 22, 2003 | 11:51 AM
mar3's Avatar
Administrator
Dear Lord!! You miss a single day and the Carter Heretics have almost condemned another soul to the grinding Hell that is their premiere fuel pump!
Listen not to this blasphemy and step into the 21st Century, Effendi....
You NEED the Mallory Comp140 which will come with a regulator in the box. Even if you decide to put your mill to the sweet juice, this will be the last fuel pump you have to buy. Gerotor technology is quieter, more efficient and the unit is rebuildable, so you won't be buying another body piece for instance....I'll dig up a pic later...
Old Sep 22, 2003 | 01:15 PM
mar3's Avatar
Administrator
<<<<sigh>>>>...so much for the pic, they lost that data as a well...
Old Sep 22, 2003 | 04:16 PM
KaiNalu's Avatar
Can someone post a link to where I can purchase this wonderful peice of machinary.
Rotospectre
Mar 28, 2018 03:33 PM
Skeese
65
Mar 28, 2017 03:30 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
