Air pump removal
Old Sep 20, 2003 | 07:12 PM
Question Air pump removal
I'm thinking of removing the air pump for added clearance. My question is will the ECM detect it not being there? Hate for a "Check Engine" light to come on. And do I need to plug anything?
Old Sep 20, 2003 | 08:18 PM
Icemastr's Avatar
All Motor
If you dont have a catalytic converter, then its all fine to remove the air pump, they're are two pipes going into the engine block that either need to be capped off, or remove the pipes and install a block off plate. Need to get a 300K4 belt, found mine at Pep Boys. Its not hard to remove the air pump, just was hard to find the belt.
Old Sep 20, 2003 | 08:19 PM
JONSKI's Avatar
5yr member, joined 2001
Have you elimated or gutted your main catalytic converter, yet?
[edit]Icemastr beat me to it.[/edit]
Old Sep 20, 2003 | 11:03 PM
duboisr's Avatar
No AIR PUMP will make the car idle rich, unless you have an aftermarket ecu or piggy back . Unplug the air pump and the ecu will not give a code .
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
