Coolant Additive Q?
Old Sep 20, 2003 | 01:15 AM
juni7's Avatar
Question Coolant Additive Q?
red line water wetter
Do i just add this to my coolant resevoir if i dont need to flush the coolant system?
Also my resevoir is past the full mark by 3 inches. Should i drain some of the resevoir and then add the red line water wetter?
thanks
Old Sep 20, 2003 | 04:18 AM
juni7's Avatar
does anyone know? the directions are not clear for adding in the additive without flushing
thanks
Old Sep 20, 2003 | 06:30 AM
CarmonColvin's Avatar
If you just add it to the resivoir it will take a while for it to get sucked into the rest of the cooling system. You should just add it directly to your radiator. Odds are your car needs it coolant flushed anyway.
Old Sep 20, 2003 | 08:16 AM
When the engine is cold, remove enough water to lower the reservoir between Full and Low lines. Is the radiator the only coolant fill arear? If yes, then add water wetter there. Mine has two, 1- at radiator, 1- at thermostat housing. I use the thermostat housing filler for coolant/additives.
Old Sep 20, 2003 | 10:06 AM
Wankel7's Avatar
Haven't we ALL heard this
Don't drain it just siphon some out
James
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
