Brake pad questions
Old Sep 18, 2003 | 10:54 AM
projekt's Avatar
Brake pad questions
i've read that the front brake pads are the same regardless of caliper used. would it be true then if i bought pads for the single piston calipers and then switched to the 4 pistons, i could just swap the pads?
Old Sep 18, 2003 | 10:56 AM
selanne8's Avatar
that would be a negatory there...
i've swapped my single piston to 4 piston calipers and the pads are different.
john
Old Sep 18, 2003 | 11:20 AM
Rxmfn7's Avatar
Do a barrel roll!
Yep, the front pads are different. Im pretty sure the rear pads are the same, reguardless of model, but the front are definately way different of the 4 piston calipers.
Old Sep 18, 2003 | 11:22 AM
fastrotaries's Avatar
W. TX chirpin Monkey
not the same amigo, sorry.
Old Sep 18, 2003 | 11:39 AM
projekt's Avatar
thanks boyeez
Old Sep 18, 2003 | 12:28 PM
mazdaspeed7's Avatar
mad scientist
Correct. The rear pads are the same(although the calipers and rotors are wider), but the front pads are different. The front rotors are the same though, for all 5 lug.
djritz
Aug 25, 2015 02:46 PM
82streetracer
Aug 23, 2015 09:28 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
