brap ... brap,brap,brap ....brap
Old Sep 17, 2003 | 10:22 PM
hondahater's Avatar
spending too much money..
Unhappy brap ... brap,brap,brap ....brap
what would make my car be idleing like this? It sucks I'm ripping my hair out over it.
Old Sep 17, 2003 | 10:24 PM
Project84's Avatar
Open up! Search Warrant!
vaccuum leak, bad timing, the green gobblin
Old Sep 17, 2003 | 10:32 PM
hondahater's Avatar
would wd40 pick up the vacuum leak if I sprayed it around there? Thanks!
Old Sep 17, 2003 | 10:36 PM
Makenzie71's Avatar
...94% correct.
B12 would...
Old Sep 17, 2003 | 10:40 PM
GTUDRIFTER's Avatar
A bridge port.....LOL
Old Sep 17, 2003 | 10:48 PM
hondahater's Avatar
lol, common I really need to know this is getting on my nerves cause I don't want to fork out the cash for a new motor but if I have to I guess I will. GRRRRRR
Old Sep 17, 2003 | 10:51 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
incorrectly set TPS and or a vac leak.
Old Sep 17, 2003 | 10:54 PM
Black13B's Avatar
In Full Autist Cosplay
Malfunctioning TPS. Try driving with the TPS unplugged and let us know if it makes a difference.
Old Sep 17, 2003 | 10:57 PM
hondahater's Avatar
ok ok ok like I said before not new to rx7's just new to mechanics (sorry). Where is the tps? and if I unplug the tps would it idle correctly becuase right now all interior is out for cleaning. Thanks.
Old Sep 17, 2003 | 10:59 PM
Black13B's Avatar
I fail to see what the interior has to do with the idle.
N/A or TII?
N/A is easy to spot. TII you have to remove the TMIC.
Old Sep 17, 2003 | 11:01 PM
Wankels-Revenge's Avatar
Defected to the dark side
I have this same problem..but only occasionally. Maybe 1 out of every 10 times i start the car it does this..for maybe 2-3 seconds. I'll fiddle with the tps more later though...no time now (school sucks).
Btw, if the car is driven with the tps unplugged...what should happen? A little more theory behind why certain things happen the way they do would be appreciated...that way i can form my own conclusions and u know..be like u incredibly smart rx-7 people
Old Sep 17, 2003 | 11:05 PM
hondahater's Avatar
the reason for idle is that if no seats, ac, instrument cluster, dash, etc... only thing I can do is idle in the garage its not really driveable the way it is right now
Old Sep 17, 2003 | 11:07 PM
hondahater's Avatar
oh ps its a tII with a front mounted intercooler. actually the stock intercooler but rerouted to the front.
Black13B's Avatar
I'm not incredibly smart. RETed and NZConvertable own me!
Amur_ had a thread recently on exactly what you described.. I believe the new (correct) TPS solved his problem.
I would have thought the car would stall with no TPS signal, but apparently it keeps in ticking. But you get a crappy throttle response when you open it up from idle.
*starts looking for Amur_'s thread..*
Old Sep 17, 2003 | 11:08 PM
hondahater's Avatar
sounds like me right now the throttle response is real bad!!!
Old Sep 17, 2003 | 11:11 PM
Black13B's Avatar
https://www.rx7club.com/forum/showth...hreadid=216766
Old Sep 17, 2003 | 11:19 PM
hondahater's Avatar
my idle is like 20 to 100 rpm realllllllll low not that high. its like brap..pap..pap...brap...pap...pap and on and on. This happens every time I start up my car. so its not intermitent it always does this, thanks.
Old Sep 17, 2003 | 11:37 PM
Davidov's Avatar
The only GOOD way is a nice bridgeport.
All the extra fuel/air makes it REALLY lumpy. Like a stroked V8 with a cam.
Old Sep 18, 2003 | 12:04 AM
dr0x's Avatar
pei > caek
... You do realize it takes <5 minutes to adjust the tps?
Old Sep 18, 2003 | 12:13 AM
razorback's Avatar
You've Been Punk'd
my bridgeport goes brap brap brap..
Old Sep 18, 2003 | 08:02 AM
hondahater's Avatar
it seems like it will idle like that while cold but as soon as it warms up to normal temp. it won't idle at all? Anyone? Thanks.
Old Sep 18, 2003 | 09:17 AM
5 point whoa's Avatar
Poor Lil' Kid
umm, sounds bad. did you check for vacuum leaks yet?
Old Sep 18, 2003 | 01:50 PM
hondahater's Avatar
no I will do that tonight! I thought if it was a bad engine it wouldn't idle period. at least this one idles up until it warms up. Thanks.
Old Sep 19, 2003 | 01:45 PM
I did that already..twice. Got that bad boy to 0.999
It could be a bigger problem...im gonna take a look at Amur_'s thread like Black13b said.
Oh thanks Black13b for the link by the way.
LongDuck
Oct 7, 2015 08:12 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
nycgps
30
Sep 29, 2015 12:02 AM
