what the hell is the sensor in the middle of the secondary rail?
Old Sep 24, 2001 | 08:24 PM
Bacon's Avatar
IRS 4 Life
ok im goin with a custom fuel rail for my bosch 16's...but it dosent have a hole for whatever the sensor thingy is in the middle of the secondary rail..is it needed? what the hell is it?
thanks
Old Sep 24, 2001 | 09:15 PM
spooledUP7's Avatar
There and back again
My first guess is that it is a fuel thermosensor but I didn't know why it was there until I opened the shop manual.
It is part of a series of switches and sensors which controls the fuel pressure regulator solenoid to control and "regulate" the fuel pressure regulator it self.
It works by sending as an inverse resistor which the ECU monitors and acts on the pressure regulator solenoid according to both resistance settings and conditional inputs from other components such as the ignition switch, neutral switch, and throttle sensor.
When hot, the fuel pressure solenoid is switched to cut vacuum to the fuel pressure regulator.
I'm not sure what affect it will have on the system as a whole, but it may return a bad error code, but the manual plays it off as a "hot start" helper as well as an idle enhancer.
Interesting
Old Sep 24, 2001 | 10:37 PM
Bacon's Avatar
IRS 4 Life
wow hella nice explination...well hopefully it wont **** off the power fc ..whenever i get it.
thanks man
Old Sep 25, 2001 | 06:18 AM
turbovr6's Avatar
I do believe it is the fuel thermosensor, you are referring to
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
