85 ,how do i find out the model
Old Sep 16, 2003 | 12:42 AM
karlcroak's Avatar
i searched but didnt know exacty what to search for .....
that being said, i just bought an 85 and there are no emblems on it , it has a 13b carberated engine and im told that setup isnt stock, it is a nikki 4 barrel. now my real question- can i find out what model it is with the vin # . if not what other things can i look for on the car ? it has a sunroof and power windows if that helps.
Old Sep 16, 2003 | 01:10 AM
peejay's Avatar
Old [Sch|F]ool
Well, there were two engines in '85, a carbureted 4 port 12A (which this isn't) and a fuel injected 6 port 13B (which this isn't).
You can tell which engine it had from the factory by the VIN. The 8th digit will be a 1 if it had a 12A and a 2 if it had a 13B.
If it originally had a 13B, it is a GSL-SE. If it originally had a 12A, then it's most likely a GSL due to the power windows. You can't really tell though because who knows what has been done to the car by previous owners. For example, if it has solid rear discs then it has a GSL axle, if it has vented rear discs then it has a GSL-SE axle, but people swap these into GS and S models all the time.
Old Sep 16, 2003 | 02:38 AM
karlcroak's Avatar
ok awsome info. the 8th vin is a one but it says right on the rotor housings its a 13b.. so someone swapped the engine..cool.. i got the car cheap they couldnt get it to run ,but it has a header and new exaust so now im wondering if this engine might be done up in any way.. im waiting for my carb kit to get here in the next couple of days (the pump diaphram is bad in the carb)and see if it will run. how do i find out if its a 4 or 6 port , im wondering because i also have an 88 and i was curious.
The1Sun
Mar 18, 2018 11:08 PM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
