Front housing/omp help or i kill my self!!!!
Old Sep 12, 2003 | 11:03 PM
85gsl2ndtimearound's Avatar
Allright im not gonna kill myself over it.......
I have used the search and could not find the info i was looking for. I need to know what is behind the omp? Well i guess what i am saying is if I were to drill Below the bottom bolt That Holds the omp on would i hit anything? Exactly 1/16th of an inch below the bolt hole and drilling a hole would be 3/16th of an inch in diamater.
Anyone picking up what i'm putting down?
Old Sep 13, 2003 | 10:24 AM
anybudy???
Old Sep 13, 2003 | 11:45 AM
Rx7carl's Avatar
Airflow is my life
Theres some space down there. Remove the cover (which you better do unless you plan to drill a hole and put shavings down in your engine), find a suitable place and drill away. What for if I may ask?
Old Sep 13, 2003 | 01:42 PM
The bottom bolt eyelet broke and I dont want to jb weld the block off plate to the cover. But if I have to remove it Ill probly just jb weld it. Thanks carl.
Old Sep 13, 2003 | 02:29 PM
Rx7carl's Avatar
Airflow is my life
The eyelet for the omp? Ow. I dunno if the jb weld will work, but good luck.
Th0m4s
Feb 26, 2019 02:04 AM
The Shaolin
Sep 14, 2015 07:50 PM
