Smoking corner lenses...need some pointers
Old Sep 9, 2003 | 01:42 PM
Scrub's Avatar
bow leggin'
What steps should I take to prep the plastic? Also, how should I go about applying it? Any info is appriciated.
Old Sep 9, 2003 | 03:34 PM
well you're gonna need a large rolling paper, and most likely a torch. I don't recommend smoking corner lenses, but the plastic should get u mad high yo.
Sorry I'm bored
Old Sep 9, 2003 | 07:05 PM
Louis M's Avatar
it'll get you fucked up!
Old Sep 9, 2003 | 07:10 PM
unvmyrx7's Avatar
scuff or wet sand the outside of the lights with 1200 grit sand paper or a scuff pad, use plastic primer if u like to prime them, its not needed, spray 2 light coats of nightshades transparent paint, then 2 wet coats. you can also purchase plastic primer and transparent paint at your local hobby shop. good luck
Old Sep 9, 2003 | 07:46 PM
Scrub's Avatar
bow leggin'
thanks a lot...I got some japanese stuff from my buddies shop...should do the same job though.
Old Sep 10, 2003 | 10:53 AM
NewbernD's Avatar
Tequila? ..it's like beer
Be sure to add a coat of clear over the tint.. I've tinted my front parking/signal lights and after a drive in the rain or two the tint got splotchy. I may clean it all off and have a go at tinting them from the inside..
ls1swap
Jun 3, 2024 03:25 PM
SRTx781
Dec 19, 2015 07:30 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
