Help - replaced starter, car won't start
Old Sep 8, 2003 | 10:18 AM
Lisa's Avatar
Ok, so yesterday I had to replace my starter. Replacing it was easy, except I had to fix a wire that broke. It ran fine yesterday, no problems at all - fired up great like it always does.
This morning, I get ready to leave for work and it won't start. No grinding, no attempting to turn over, nothing. Turn the key and there's just silence. It's not the battery, it's got power. Any suggestions?
Old Sep 8, 2003 | 10:27 AM
JLIU's Avatar
make sure that little wire is attatch to the starter aside the cable from the positive terminal of the battery.
Good luck
Old Sep 8, 2003 | 11:08 AM
Lisa's Avatar
All of the wires are attached. Everything else has power - gauges, radio, lights, everything - so I don't think I grounded out. C'mon, guys. Someone's gotta have ideas. Is it possible I fried the new starter somehow?
Old Sep 8, 2003 | 11:32 AM
MarkPerez's Avatar
Tennis, anyone
I don't think you fried the starter. check your fuses under the dash.
Old Sep 8, 2003 | 03:00 PM
Lisa's Avatar
Fuses are all good. Connections to the battery are good. Maybe I got a bad replacement starter? After work, I'll take it off & have it tested.
Any other suggestions?
Old Sep 8, 2003 | 03:08 PM
Rx7carl's Avatar
Airflow is my life
Have the starter checked. Its possible your ign switch has gone out. WHy did you change the starter in the first place? Intermittent operation?
Old Sep 8, 2003 | 03:19 PM
Lisa's Avatar
Started out intermittent operation, then went to that nasty grinding sound, then just stopped working altogether. Hmm... ignition switch - how'd I know if that went out? Key turns, when it does it cuts out the radio and stuff...
Old Sep 8, 2003 | 04:19 PM
MarkPerez's Avatar
Tennis, anyone
Thoses are the signs of a starter going out. You know lots of people have at least 10 lbs of keys on there key rings. You know what kills ign. switches the fastest.....
tons of keys on the key rings.* While the starter is out,
put a meter on the battery cable that goes to the starter
and see if thats good, while your there.
Old Sep 8, 2003 | 04:28 PM
FB II's Avatar
hey, i had this problem once when i put my new starter in , a week later it did nothing. do you have an oil leak by chance anywhere? my oil cooler sprayed oil on the connections. i just cleaned them off and it worked. try hitting it once, maybe the solenoid is mad? lol. sry i am out of ideas.
Old Sep 8, 2003 | 06:18 PM
Rx7carl's Avatar
Airflow is my life
If it acts up again, jiggle the key while trying to start it. See if it starts that way.
Old Sep 8, 2003 | 07:57 PM
mar3's Avatar
Administrator
Did a quick search for your symptoms in particular and came up with this by moi...
An Alternative Solution to a "Bad Starter"
Old Sep 8, 2003 | 09:26 PM
Papasmurf's Avatar
When I changed the starter, I had the same problem. It took me forever to figure it out, finally I nailed it down to the battery clamps, changed them, starts everytime now.
Old Sep 9, 2003 | 01:55 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
I wiggled my fusible link wires and it went away.
Old Sep 9, 2003 | 01:20 PM
Lisa's Avatar
Thanks, everyone, for your help. Fixed the problem - there were actually two.
Like I said before, one of the wires broke (at the quick connect), so I'd spliced in a new one - guess I didn't go far enough back to get good wire for a strong connection, so I redid that. And that damn little sensor wire popped off - put it back on, still didn't work, so I cleaned it - BAM - works fine now.
Again, thanks for all the help & suggestions!
alphawolff
Nov 17, 2015 05:57 PM
torky007
Aug 17, 2015 05:14 PM
befarrer
Aug 14, 2015 04:18 PM
