Idle bounces abit constantly, help please :)
Old Sep 8, 2003 | 05:52 AM
KarmaCult's Avatar
Hi hi
Just afew questions about my idle, ok, first off, my idle bounces at all times while the car is on (because it doesn't idle when its off ) its set to 850 rpmish (give or take abit) and it bounces from anywhere from 250rpm to 1k rpms at all times while I'm idling (for the most part), is there anyway to pin point what could be causing this? like any common problems I should look into?
ok, this may sound stupid, but in hopes that you all are understanding and don't call me stupid is the idle screw suposed to have vaccum pressure coming past the screw? if I start my car and stick my thumb where the idle screw is, I can feel air getting sucked into the engine (or what have you) from where the screw is, this is a 13b FI just in case your wondering
Oh, and off topic, my interior lights (the two on the rear view mirror) are sometimes working, sometimes not, its mostly based on luck wiether it works or not, I have chased the wires and what have you the best I can without taking everything apart (interior), and I havent found anything wrong I don't think, so it there anything that commonly causes this that I should check out? Any help on any of these would be very appreciated
-KarmaCult
(Please also read my signature )
Edit: added light question
Old Sep 8, 2003 | 09:48 AM
vladu13's Avatar
Your bouncing idle could be the fault of a bad shutter valve. Do a search for this. There was a big topic about this type of problem not too long ago.
Old Sep 8, 2003 | 01:46 PM
nlc1179's Avatar
it seems like this sort of thing happens to pretty much every gsl-se. mine had the same problem. you might what to check your throttle positioning sensor. when they go bad, they do weird things. it could also be a shutter valve like vladu13 said. there are about 100 other things it could be though. do a search.
Old Sep 8, 2003 | 01:55 PM
BigJim's Avatar
trainwreck
as for your lights are you talking about the lights that turn on when your door opens? if so mine did the same thing so i unhooked my power, got some dw-40 and sprayed it on the button that tells everythign when the door isopen, be sure to unhook your power otherwise you might short soemthing out, did that with my tv remote once so now before i use liquid on anything i make sure there is no power
Old Sep 8, 2003 | 04:18 PM
Metallic_rock's Avatar
Ride 'n Style
Napa sells spray electrical cleaner... evaporates quickly... definitely remove power first.
kuuva86
Sep 28, 2015 05:42 AM
Jmolina0163
19
Sep 25, 2015 06:06 PM
ZacMan
Sep 19, 2015 09:20 PM
ChanBagz
Sep 17, 2015 03:36 PM
Im faster
Sep 10, 2015 04:38 AM
