Reinstall Lower Control Arm
Old Sep 6, 2003 | 11:26 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
how hard is it to put a new control arm in my car? is it just a bolt off...bolt on affair....how hard is it?
thanx,
Gufran
Old Sep 8, 2003 | 06:34 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
This is an easy installation, since it's really just the following;
1) SAFELY jack car,
2) remove wheel
3) remove sway bar link
4) remove 2 17mm bolts holding shock strut to lower control arm
5) Use 2x 14mm openend wrenches to remove lower control arm bolt.
This removes the arm, and then you can use a gear puller to take off the cotter pin, castlenut, and lower spindle (with steering arm).
I changed mine out in about 2 hours, both sides, but be sure that you get lower control arms with inside bushings installed, plus ball joints installed. Mazdatrix has these cheapest, i.e., full setup for $130 each, IIRC. Victoria British makes you buy all parts separately for a lot more than that.
Increases front stiffness and restores ride feel and steering response. Definitely worth doing,
Old Sep 9, 2003 | 02:17 AM
REVHED's Avatar
Hunting Skylines
That's basically it. The only thing not mentioned was that the castor rod also bolts to the control arm.
fjwheeler
22
Jan 9, 2022 01:02 PM
pfsantos
Canadian Forum
Oct 19, 2015 07:04 PM
GrossPolluter
Aug 15, 2015 10:32 PM
