center vent removal
Old Sep 5, 2003 | 07:47 AM
platinumblack's Avatar
center vent removal
does anyone know how to remove the center vent?,the one right below the speaker.i have a '94.
Old Sep 5, 2003 | 10:23 AM
weblair24's Avatar
It should just pop out. Use small flat head to get under the edge.
Old Sep 5, 2003 | 04:27 PM
saxyman990's Avatar
Place your ad here...
I was just gonna ask this! Thanks for the help weblair24. Mine still doesn't seem to want to come off though, and I feel like I'm about to brake it. Is there some special trick that'll help?
Rob
Old Sep 5, 2003 | 10:46 PM
weblair24's Avatar
Try prying it up enough to get youre fingers under it and pull up. I thought mine was gonna break too, it popped out with some force right into my window, no damage though.
Old Sep 8, 2003 | 08:49 PM
ZeroBanger's Avatar
Did you guys know that there is a screw behind it and to remove it without breaking something is to do from behind the dash?
I too pryed mine, it broke where the screw connects. No big deal the tabs will hold it in place anyway.
Old Sep 10, 2003 | 10:39 AM
saxyman990's Avatar
Thanks for the info zero. Can this screw be accessed by crawling underneath the dash? Or would it require the removal of the entire dashboard to do properly?
I need to get my center vent off, but I'd rather do it in a non-destructive manner if possible. Thanks for the help.
Rob
Old Sep 11, 2003 | 09:30 PM
saxyman990's Avatar
UPDATE
I was able to get my vent off today. For those that are interested, ZeroBanger is correct, there is a screw on the back side of the vent. In fact, there is more than one screw.
There are two screws holding the vent to a small metal bracket, and then there are two more screws holding the bracket onto the dashboard. If you remove the AC Panel (a not-so-easy task), then I'm pretty sure the lower screw would be accesible. However, I don't think it'll be possible to undo the upper screw without removing the entire dashboard.
I was able to pry mine apart. It broke at the screw points similar to the way ZeroBanger's did. However, if you are not careful, you could probably break the vent itself (I'm actually suprized that I didn't break the vent).
Old Sep 13, 2003 | 08:13 PM
ZeroBanger's Avatar
Re: UPDATE
yea, I found the screws are not necessary anyway. the vent snaps in by the side clips. Its just another form of retarted mazda engineering. similar to the way you have to take the doors off to remove the speaker covers (I broke those too, now its held in by silicon).
Monsterbox
Jul 29, 2022 10:48 PM
