restarting an unused car
Old Sep 2, 2003 | 02:30 PM
jj24's Avatar
Newbie
I have a 1982 RX-7 GS with the 12A engine and 63,000
miles. It ran fine when it was last used, about 10 years ago. I am looking for advice on how to go about getting it back up and running. Any help would be appreciated.
I am in Columbus, Ohio.
Old Sep 2, 2003 | 03:43 PM
The_7's Avatar
Registered Piston Eater
have you tried to start it yet?
Old Sep 2, 2003 | 03:46 PM
Metallic_rock's Avatar
Ride 'n Style
pour Marvel Mystery oil down the carby and let it sit for a while... then try to start it. You don't want stuck apex seals poping out just because they were sitting in there.
Actually, I'd recommend pulling the plugs and trying to spin the engine over by hand. (put wrench on the E-shaft bolt and spin it over.)
Old Sep 2, 2003 | 07:01 PM
JIMMY54's Avatar
GSL-SE PRO
If you haven't already DRAIN the gas. That really important....I thought it wouldn't be a big deal and tried to start it...I ended up ******* up my fuel filter, injectors etc.
Also change the oil.
Old Sep 2, 2003 | 07:10 PM
locklej's Avatar
I would flush everything and replace all the filters, spark plugs, and seriously consider a close inspection of the carburetor. I purchased a rx7 that had been setting up for 4 years and the carburetor was gummed up real bad.
Old Sep 2, 2003 | 08:23 PM
hornbm's Avatar
FD > FB > FC
When I got my seven it had been sitting for about a month or so, and it didnt want to start.
My dad poured some gas down the carb and it fired right up.
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
zuesskroph
Aug 13, 2015 06:05 PM
