Problem, and random questions
Old Sep 1, 2003 | 03:25 PM
BigJim's Avatar
trainwreck
First off i have 1 major problem. Wheni start my car, itl rev itself up ti like 2.3 grand , then drop to about 1 thousand and idle nicely, or when i start it itl rev to about 2 grand drop to about 400 almost stall, recover and idle nicely at about 800 rpm. Or itl rev up to about 1.5 grand, drop to about 1.2 and then to 800, then back to 1.2 then nback to 800 over and over. What would u say normal idle is and how can i get mine to idle better. I have a 84 GSL-SE fuel injected.
My ownly random question is, well have any of you ever placed in a car show. I was considering redoing my entire car and starting to show it, but i want to see if i even stand a chance.
Old Sep 1, 2003 | 03:46 PM
The_7's Avatar
Registered Piston Eater
sounds like a vacuum leak possibly, you should check around and see if you can find one
Old Sep 1, 2003 | 09:04 PM
specRX7_22's Avatar
the anti-afterburn hose under the carb messes with idle... and is known to sorta melt from the manifold heat inches below
Old Sep 2, 2003 | 03:26 PM
BigJim's Avatar
trainwreck
My car is fuel injected so i dont know if it still has same prob as carbed ones
Old Sep 2, 2003 | 05:33 PM
specRX7_22's Avatar
ahhh nevermind then
diabolical1
30
Jan 30, 2016 05:50 AM
alphawolff
Nov 17, 2015 05:57 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
