where can i buy wheel studs for an 87 t2?
Old Sep 1, 2003 | 02:21 AM
razorback's Avatar
You've Been Punk'd
where can i buy wheel studs and lug nuts for an 87 t2? i cant find them anywhere.
Old Sep 1, 2003 | 03:22 AM
Ni5mo180SX's Avatar
White Comet
Dealer. Front is like $5 each and rear is about $3.
Old Sep 1, 2003 | 03:29 AM
razorback's Avatar
You've Been Punk'd
ok thanks. is that per stud ?
Old Sep 1, 2003 | 01:32 PM
Ni5mo180SX's Avatar
White Comet
Yea, per stud.
Old Sep 1, 2003 | 04:31 PM
razorback's Avatar
You've Been Punk'd
im getting new brake rotors. do i have to replace all fo the studs when i put the new rotors on?
Old Sep 1, 2003 | 08:50 PM
EL PAALO's Avatar
Replacing the studs because you're getting new rotors?
Old Sep 1, 2003 | 10:41 PM
Ni5mo180SX's Avatar
White Comet
Old Sep 1, 2003 | 11:25 PM
razorback's Avatar
You've Been Punk'd
no two studs are broken. and someone told me that i have to replace the wheel studs when i replace the rotors. but i take it that wrong?
Old Sep 2, 2003 | 11:27 AM
Ni5mo180SX's Avatar
White Comet
Not necessarily but depending on which method you choose, you'll have to remove the rotors anyways. After removing rotors, take the hub off and take it to a shop to have the new studs pressed in.
The only alternative that I know of is once you remove the wheel, hammer the old stud out (sledge hammer) and then feed the new stud through the backside of the hub. You have to be very careful to make sure the splines match up and then you can drive it in using a lugnut on the threaded side, continuing to tighten until its pulled in entirely. Hope that helps.
ChrisRX8PR
Aug 21, 2015 01:56 PM
need RX7
11
Aug 19, 2015 08:27 AM
