will fuel injection cleaner harm the rotoary engine?
Old Aug 31, 2003 | 08:35 PM
SF@Rx7's Avatar
i bought the chevron pro-gard fuel injector cleaner
after i used it the car started leaking
and it said on the bottle not recommended for air-colled two-cycle engines is that talking about the rotary engine?
Old Aug 31, 2003 | 08:46 PM
PraxRX7's Avatar
bleh
Air cooled 2 cycle is like a snowmobile.
But I don't think once in a while that fuel injector is a bad thing...just dont use that cleaner that goes in every tank...I used that crap on my Turbo II and it wouldnt idle until I ran some 2-stroke non-synthetic pre-mix through the gas.
Old Aug 31, 2003 | 08:51 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Well, those cleaners are designed for piston engines. Piston engines can swallow quite a bit of harsh detergents and such, but a rotary engine has sensitive parts because it's a precision machine--not a reciprocating mess of parts!
Anyway, in conclusion, those cleaners have abrasive junk that will harm rotary engines. I, and many of the people here, will recommend using MMO (Marval's Mystery Oil) to clean the engine. Add some to your oil and gas, maybe pour some down the carb, and you're set!
FS
Old Aug 31, 2003 | 09:10 PM
RacerX7fb's Avatar
paradox
Leaking what and where???
Being more specific allows us to help you alot better
Old Sep 1, 2003 | 11:53 AM
SF@Rx7's Avatar
the engine leaks
i think it is the gasket leaking
but after a while it leak less now
Old Sep 1, 2003 | 12:15 PM
faye x7's Avatar
brilliantly stupid
Leaks....er..what?
Old Sep 1, 2003 | 12:43 PM
SF@Rx7's Avatar
Originally posted by faye x7
Leaks....er..what?
leaks engine oil
Old Sep 1, 2003 | 01:28 PM
FuLLsMoKe's Avatar
From the oil pan area? From the housing sections? From the exhaust manifold area? Where?
FS
Old Sep 1, 2003 | 09:18 PM
SF@Rx7's Avatar
i think oil pan but not sure about it
Old Sep 1, 2003 | 09:35 PM
1984special's Avatar
So little time and money
Is MMO ok for FI cars (GSL-SE)? Because I don't have a carb to pour it down...
Old Sep 2, 2003 | 02:01 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
You can premix it in with your gas. Normal premixing ratio is usually 16oz of MMO per full tank (no OMP). Since you are only using it to clean the motor, I recommend you use either a 16 oz bottle in with the oil or 8 oz to a full tank of gas. I doubt the MMO will clog your injectors with such a small ratio.
Old Sep 2, 2003 | 01:14 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
i run GUMOUT carb cleaner in it all the time, keeps the fuel system clean and zippy.
dkwasherexd
May 27, 2017 04:51 AM
pzr2
Aug 15, 2015 08:29 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
