turob question
Old Aug 29, 2003 | 11:35 PM
turob question
what do u guys think bout a 12A draw through turbo kit is dwar through any good or is it bad and around how much hp should i see using a 48ida carb setup.
Old Aug 29, 2003 | 11:40 PM
Pedestrian X's Avatar
SpAz!
well i think blow through is alot easier and i think moajority, LARGE majority, of peopel turboing there rotarys are going wioht a blow through setup. your HP will totally depend on you entire setup liek IC or no? how much boost. the turbo you will be using etc..
Old Aug 30, 2003 | 03:38 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
You sure as hell better port it if you're gonna use a 48IDA.
Old Aug 30, 2003 | 02:37 PM
FB II's Avatar
nah 48 will be fine as long as it's tuned right. use smaller horns.
Old Aug 30, 2003 | 03:23 PM
SpAz!
one more thing, SEARCH!
Old Aug 31, 2003 | 09:20 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
A draw through limits options. You'll be ok with a Dellorto, but since the mixture will be drawn through the carb, and then through the turbo you cannot use a IC. You'll need to keep the intake lengths as short as possible, since the longer length might let the fuel the mixture to become liquid again. This is a typical problem, and makes little fuel puddles occur in the intake housing of the turbo, especially when you'd have the car running too rich.
A blow through will only draw air through the turbo, and therefor leaves more options open. You can use a IC, and a blow off valve.
In Europe (UK) there was a kit developed for the first gen (no longer available) that had a draw through setup. The cars did become very different with that kit installed. It only used a small turbo, and an SU carb. But still managed some good power.
It's mainly a matter of choices, and budget. Of course you must be carefull not to spend more on a good 12AT setup then it'd cost you to do a TII swap that might give you as much power. After all, don't expect 250 or 300hp from a draw through carbed setup!
Old Aug 31, 2003 | 05:37 PM
REVHED's Avatar
Hunting Skylines
You can definately make some big power using a draw- through turbo. At one stage the quickest untubbed rotor here was in the 9's running a draw-through setup.
I don't see how you could use an IDA as it's a down-draft carb so you're basically limited to a DCOE. It's gotta be big to flow enough air (like up to 55mm) and you need some form of charge cooling like water/methanol injection.
Apparently streetability on these things is a real bitch because of things like heat soak which causes hard starting and they tend to be dogs off boost.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
