Will a 84 12A AC setup fit an 84 13B?
Old Aug 28, 2003 | 12:09 AM
TexasGunRunner's Avatar
Will the compressor and bracket from an 84 12A fit the 13B from a GSL-SE of the same year?
I am assuming the evaporator and condenser are the same, but what about the tubes, drier, and expansion valve?
In the past, I've seen manufacturers switch compressors several times during a model year (based on the deal of the month I suppose), the brackets usually match. Do the brackets match on the engine 12A and 13B?
If not, I wonder if the bracket from another 13B will fit that compressor?
Any help will be appreciated.
Thanks,
Brian T. Carter
Josh83rx7
Sep 2, 2015 05:57 PM
Inspector71
Aug 26, 2015 12:06 PM
