repairing small radiator crack
Old Aug 25, 2003 | 08:15 PM
The_7's Avatar
Registered Piston Eater
there is a small crack right were the small piece of pipe that the heater hose is welded on at the bottom of the radiator. there are many different ways to seal it, which would be the best one?
Old Aug 25, 2003 | 08:34 PM
wagondriver69's Avatar
Old Aug 25, 2003 | 08:35 PM
rotor vs. piston's Avatar
Function > Form
Old Aug 25, 2003 | 08:36 PM
Function > Form
Just make sure you clean the surface very well
Old Aug 25, 2003 | 08:48 PM
Tripple 7's's Avatar
Solder it.
Old Aug 25, 2003 | 09:01 PM
Rx7carl's Avatar
Airflow is my life
Thats tought to do on brass if you dont have the proper tools and know how.
Old Aug 25, 2003 | 09:38 PM
The_7's Avatar
would solder hold up good?
Old Aug 25, 2003 | 11:57 PM
rhinor61's Avatar
SO is this your overheating problem that you talked about earlier postings?
Take it to a radiator shop and spend the $35 and get it done right, OR you can spend $6 on a pack of JB Weld. IT might hold.... for a while... then save up for a new motor.
Come on does everybody on this forum have to short change ever repair.
Is this car becoming the Pinto of this century, bailing wire is the next thing to try.
Old Aug 26, 2003 | 12:24 AM
rxtasy3's Avatar
The best and only way to repair copper radiators is to have it re-soldered. I used to do radiator repair and believe me, JB Weld doesn't work. I hated it when ppl brought radiators in to be repaired after they tried JB Weld, that **** stinks when it burns.
Old Aug 26, 2003 | 02:06 AM
The_7's Avatar
this could be a stupid question and please exuse it if it is, but would the solder for electronics work at all?
and rhinor61, no that isnt my overheating problem, i cracked it when i was taking things apart because i bent it and then i bent it back and i think that made the little crack.
Old Aug 26, 2003 | 07:15 AM
Rx7carl's Avatar
Airflow is my life
Nope different solder, and youll need a torch to braze/solder it. Take it to a shop, if its a small repair, and you bring them the radiator out of the car, itll be a cheap fix.
Old Aug 26, 2003 | 09:35 AM
RXTbone's Avatar
Do yourself the favor - take it to the shop. My $.02.
Old Aug 26, 2003 | 10:00 AM
bliffle's Avatar
Take it to the shop. If you're inexperienced and attempt the solder yourself you may end up with more problems. JB weld is epoxy, and epoxys worst enemy is hot water.
That's a nice looking car, RXTbone.
B
Old Aug 26, 2003 | 01:12 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
buy a NEW RADIATOR
Old Aug 26, 2003 | 01:20 PM
Anex 570's Avatar
It Runs!
I just got my 79 radiator fixed for $15 from the old guy that repairs radiators. Very good job and he'll back up his work if it fails. I cant wait till May when my car will be a classic!!!
Old Aug 26, 2003 | 02:18 PM
The_7's Avatar
ok guys im gonna take it to shop soon, im gonna have them clean it out too.
buy a NEW RADIATOR
i would if i could afford it
Old Aug 26, 2003 | 06:07 PM
bliffle's Avatar
Good move.
B
Th0m4s
Feb 26, 2019 02:04 AM
