WRX rims on an S4 RX7
Old Aug 25, 2003 | 01:18 PM
JGard18's Avatar
Will it work?
WRX rims are 5x110, and I believe the offset is somewhere around +38mm.
i have no idea what the RX7 has for that stuff. Oh, and rim dimensions of the WRX are 16x6.5
I could get some for cheap, which is why I'm wondering if they'd fit. I want two sets of rims, one for winter and one for summer. Thanks.
edit: I'm about to pick up an 87 GXL...
Old Aug 25, 2003 | 02:50 PM
Cheers!'s Avatar
Former Rx7 *****
no... rx-7s have 5x114.3 mm bolt pattern.
Old Aug 25, 2003 | 03:27 PM
Fish's Avatar
As Cheers has said, the PCD is incorrect, and the rims from the WRX are not wide enough.
You want to look at something a little wider being around x8 wide.
Dan
Old Aug 26, 2003 | 06:58 AM
JGard18's Avatar
cool, thanks.
Old Aug 26, 2003 | 09:07 AM
Travis R's Avatar
trying to build a racecar
WRX rims are 5x100, 16x6.5, with a 53mm offset. The offset is really high on Subarus because of the wide bearing spacing in the hubs. It gives them more strength for rallying.
Old Aug 26, 2003 | 09:40 AM
JGard18's Avatar
It also causes their bearings to fail often (yep, I'm a regular on www.nasioc.com)
Old Aug 26, 2003 | 11:19 AM
Travis R's Avatar
It's not the wide bearing spacing that causes them to fail. I haven't heard of any bearing problems recently. I know it was a problem on the older GC8 chassis cars, but it usually didn't show up until you ran wheels with the wrong offset. Then it was a perpetual problem because the dealerships couldn't reinstall them very well.
Old Aug 27, 2003 | 10:49 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
sorry.. just couldn't stop staring......
mm...
Old Aug 27, 2003 | 05:58 PM
BoOsTin FD's Avatar
Powered by** Rotary
damn nice signature
