HKS Manifold.
HKS Manifold.
What is the Largest Turbo that could be run on a HKS T4 manifold on a FD (13b-rew Engine)?
I remember reading a while back that some one had tried to fit a T66 on one and the Comp Housing caught the Inlet manifold? I am not sure if it was the same Manifold though as i looked at many and it was along time ago.
The Manifold is'nt fitted at the moment, i had thought of putting it on with a T04E thats knocking around and measuring the free space but i would not be much better of as i dont know how much wider the T66 is?
The other option thats in the Pipe line is to fit a T04S?
Cheers
Chris
Cheers
Chris
You can get a spacer (either custom, or I believe HKS actually sells one) and fit a larger hotside on there with little or no problems. I've seen it done on an FC, but not personally on an FD.
Ok i'm even more confused now?
I have just seen a 60-1 on a HKS Manifold fitted to a Fd.
I am missing somthing? He has a .84 on it but looking at the pics i cant see it close anywhere?
http://www.rotaryextreme.com/t60-2.jpg
http://www.rotaryextreme.com/t60-1.jpg
Chris
Chris
Trending Topics
Re: HKS Manifold.
The manifold you posted is for FC.
Chuck Huang
Chuck Huang
Cheers
Chris
Cheers
Chris
The HKS cast manifold for the FD can only fit up to 0.84 on the turbonetic turbo but if you have a Garrett turbo, it can fit 1.15. The reason is the turbonetic turbine housing has thicker casting. Given the same a/r, the turbonetic turbine housing is bigger than the garrett one on the outside.
Just buy my kit and save the headache. =)
Chuck Huang
Chuck Huang
