Someone wiith some inginuity please...
Old Aug 23, 2003 | 08:50 PM
85gsl2ndtimearound's Avatar
So while i was re-installing my OMP block off plate(desinged buy one Peter A.Trapino)the lower bolt hole snaped into three peices.
So just short of removing the front housing and swaping it what can i do ie. will it withstand welding of some sort or would that mess up the oil pump chain or bearings. Or is the some sort of jb weld i could use. Or could i drill and tap just to the left of the existing hole.
Any input would be great.Thank everyone who respond for your time.
Peter A.Trapino
Old Aug 23, 2003 | 09:11 PM
The_7's Avatar
Registered Piston Eater
do you mean the plate broke or the front housing? im guessing the housing because if it was the plate you would just replace it right? well, the jb weld would probably work pretty good. you could get a new front housing from a junk yard. personally i would use jb weld for good sealing and use the good bolt hole(s) as well to prevent any severe vibration from knocking the plate off. then i would look around different junk yards for a good deal on a new housing
Old Aug 23, 2003 | 09:14 PM
can i replace the housing without pulling the engien
Old Aug 23, 2003 | 09:42 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
It's the front cover not the front housing, and yes, you can replace it without pulling the engine. Just have to support the motor.
Old Aug 23, 2003 | 10:19 PM
Could i jbweld the block off plate to the front cover? And any one done it before?
Old Aug 23, 2003 | 11:11 PM
How hot does the front cover get ?
Old Aug 24, 2003 | 08:47 AM
anyone?
Old Aug 24, 2003 | 10:11 PM
Rx7carl's Avatar
Airflow is my life
I dont think itll hold up with jb weld. Best bet is to swap out the cover or have it welded by a competent welder, then re-drill and tap. And beware of the pitfalls of the front cover/pulley hub removal replacement.
http://www.mazdatrix.com/faq/pulley.htm
Old Aug 25, 2003 | 07:31 AM
jimmdog's Avatar
I would'nt think the cover would get over 200 deg. JB weld is worth a shot. What do you have to lose?
If it leaks replace the cover. Good Luck
Old Aug 25, 2003 | 10:33 AM
I'd go with a new front cover. JB weld should do the job, but the problem is going to occur if you ever need to take the plate off.
Old Aug 25, 2003 | 11:37 AM
Metallic_rock's Avatar
Ride 'n Style
I have a spare front cover. PM me if interested.
Old Aug 25, 2003 | 11:40 AM
Well i think my only option is to jbweld the plate to the front cover (I dont have the time,tools, or space the remove the front cover. So what do you guys think the best material to use. I have 1/8 and 1/4 allum. stock but would steele work better. I also have some thin tin would that be ay good? thanks for all the help everyone.
Peter A.Trapino
Old Aug 25, 2003 | 12:51 PM
Wankelguy's Avatar
I'd use aluminum so that the thermal expansion characteristics will be the same as the aluminum front cover. Make sense?
Old Aug 25, 2003 | 01:05 PM
I thought the front cover was cast? also what type of 2 stroke do i use to pre mix?
Old Aug 25, 2003 | 04:22 PM
13B4port's Avatar
Will Work for Beer
i have a front cover from a 88 if you want to put the bolt hoels in it. i'll sell it cheap.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
bb6guy
Aug 12, 2015 03:29 PM
SpiritRex7
Interior / Exterior / Audio
Aug 13, 2004 11:57 AM
Jodoolin
Sep 19, 2003 02:10 PM
moremazda
1st Gen Archive
33
Sep 24, 2002 06:51 PM
