How to remove the E-brake.
Old Aug 17, 2003 | 03:53 PM
Montic's Avatar
Im doing to LSD swap on a 83 GS, Thanks to steve I have the rearend. All I need is to figure out how to remove the damn ebrake lines out of the drums. the rear end is hanging on by those two cables. Please. Thanks
Nick
Old Aug 17, 2003 | 05:26 PM
1st to 3rd's Avatar
Are you swapping the entire rear end (with disks)?
If so you need to change the rear section of the cables. There is a connection just in front of where it passes through the frame.
Old Aug 18, 2003 | 11:36 AM
Bruceman's Avatar
Rotor Power Rules
1st to 3rd is correct. One each side the cable passes through the chassis frame. A clevis and pin join the cables here. They are probably corroded and be a bitch to take apart. The exhaust shields don't help access to on the right side either.
Just got to take your time and deal with it!
Old Apr 20, 2006 | 06:00 PM
DwArF's Avatar
vrrmmmmm
I took off the thing that right before it went through the frame and the end of the pin is stuck on that side with the wire going into my drum brake. and the other side of the wire is just hanging on the other side of my chasis where it goes through it
Old Apr 20, 2006 | 07:18 PM
$100T2's Avatar
On the prowl for an FB
Nick
I just did this exact swap. My new rearend came with cables, so I just cut those *******. If you can't cut them, try disconnecting them up by your catalytic. They attach to the rest of the ebrake line about 2 feet from the rear end... It's just a little pin with a cotter pin I think.... I haven't attached my new ones yet, but I'm 90% sure it's just a cotter pin.
Old Apr 20, 2006 | 09:01 PM
ChasRX's Avatar
I just did mine a couple of weeks ago. Check out the entire write up with pics!
http://www.cardomain.com/ride/2141550/6
Old Apr 21, 2006 | 03:16 AM
7aull's Avatar
RX HVN
Chas!! EXcellent tutorial - pulled it immediately for my upcoming swap - many thanks for the time and effort in documenting and posting this - wow!!!!
Stu Aull
80GS
Alaska
Erosangel
Sep 18, 2015 04:06 PM
Steelwheelz
Sep 15, 2015 03:22 PM
