12a engines
Old Aug 14, 2003 | 12:57 PM
dnlloran's Avatar
Question 12a engines
Hello, It is me again, with another newbie guestion.
Will a 12a engine from a 1980 RX-7 fit in a 1984 RX-7 that had a 12a engine in it?
D.
Old Aug 14, 2003 | 12:59 PM
vipernicus42's Avatar
Rotoholic Moderookie
Short answer: yes
Long answer: *might* need a different flywheel, and some other small mods, but the engine itself is a drop-in. Or at least should be.
Anyone else wanna chime in?
Jon
Old Aug 14, 2003 | 01:05 PM
dnlloran's Avatar
Thanks Jon,
I found a used 12a engine out of a 1980 RX-7, and was wanting to put that in my Rex while I rebuilt the one that is sitting in it now.
D.
pratch's Avatar
Mazspeed.com
Actually the flywheel is balanced to the counterweight in the engine. So if you switch the engine, you'll take the flywheel and starter with it.
Or rather bring the starter to the new car. Didn't mean to give the impression that the starter was somehow attached directly to the engine in any way
Old Aug 14, 2003 | 01:19 PM
dnlloran's Avatar
The person that is selling the engine says that he bought the vehicle for the (racingbeat) flywheel and carb., and that he does have a stock flywheel for the engine he is putting the (racingbeat)fly wheel on. is this going to create problems with either engine or my tranny?
D.
Old Aug 14, 2003 | 01:35 PM
pratch's Avatar
Mazspeed.com
Here's (how I understand at least) how it could effect things.
A) Different year engines had different teeth ratios on their flywheels - hence why different starters have different teeth patterns and must be used to match.
B) Depending on the flywheels' weight and the counterweight installed, if those two don't match properly you will have some rotational instabliity on the engine in addition to putting unbalanced loads on the eccentric shaft.
I could be misinformed, but as far as I know, that's the reason behind the always-match-your-flywheel-counterweights-and-starter rule
Old Aug 14, 2003 | 01:54 PM
nipper's Avatar
12a engines
I've done the swap. Yiu don't have to worry about flywheel/starters, However the intake and exhaust and emissions from the newer[1984] will have to be put on the 1980 block. Yes, carb and emissions too.
Old Aug 14, 2003 | 03:10 PM
Jeff20B's Avatar
Lapping = Fapping
An '86 or later NA starter fits a '74 REPU heavy stock flywheel just fine. It also fits any 12A with a stock or RB aftermarket flywheel, as long as it's NA.
Old Aug 14, 2003 | 03:22 PM
dnlloran's Avatar
let me see if I have got this right, it would be better for me to have the original flywheel and starter, but not neccary as long as I use the 84 carb, intake and exhaust on the 80 12a. emissions are not a concern in my area as of yet.
D.
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
