"Add Coolant" comes on every week!
Old Aug 12, 2003 | 05:13 PM
bliffle's Avatar
The "add coolant" light comes on and I gotta add a cup of water every week. Do I have blown seals?
B
Old Aug 12, 2003 | 05:19 PM
redrx's Avatar
I hate that ****, I have the same problem, most likely a radiator leak
Old Aug 12, 2003 | 05:38 PM
Gatorgunner's Avatar
yep thats what mine was
Old Aug 12, 2003 | 05:52 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
Check the radiator and all the lines. If you find no signs of leak you have a blown water seal.
Old Aug 12, 2003 | 06:43 PM
inittab's Avatar
I read your email
Since your coolant leak is small it might be hard to find the leak. I suggest that you do a cooling system pressure test. The equipment is expensive so it might be best to just bring it to a reputable radiator shop.
Old Aug 12, 2003 | 08:18 PM
rlking's Avatar
replace the cap with a mazda cap
Old Aug 12, 2003 | 08:19 PM
rlking's Avatar
make sure your recovery tank is not leaking
Old Aug 12, 2003 | 08:22 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I'd suspect the pressure cap, too.
Old Aug 12, 2003 | 09:20 PM
Ultralights's Avatar
Last time my 7 had a problem like this, it was a leaking water pump!
Old Aug 12, 2003 | 09:47 PM
mar3's Avatar
Administrator
There also o-ring seals in the intake manifold to block interface that like to go out....check any and all of the above before the next light to come on sez...Replace Engine...
Old Aug 12, 2003 | 11:48 PM
Matty's first 1st Gen's Avatar
Boosted 7
add a bit of "Leak stop" to the rad, run it for fifteen minutes, If that doesn't take care of it you may have a serious problem.
Old Aug 13, 2003 | 03:28 AM
bliffle's Avatar
All cooling system parts were replaced last year.
B
Old Aug 13, 2003 | 04:17 AM
Cody's Avatar
SKELETOR!
just smash the bulb behind the ADD COOLANT light.
Old Aug 13, 2003 | 05:34 AM
RotorMotorDriver's Avatar
Seven Is Coming
Just top it off before the light comes on
~T.J.
Old Aug 13, 2003 | 09:28 AM
bliffle's Avatar
I'll have it pressure tested and flushed.
B
Old Aug 15, 2003 | 01:54 AM
FJ's Avatar
FJ
Re: "Add Coolant" comes on every week!
B
A pressure test will help you find an external leak, but the best way to check for bad water seals is to remove the rad cap from a cold engine and start it. Once the thermostat has opened, look into the rad neck and check for bubbles. Bring the RPM up to 2000 or so. With bad seals you'll see anything from "champagne" type bubbles to large blurbs of air.
But if you do not have white smoke when starting the engine cold, it's not likely the seals.
-John.
Old Aug 15, 2003 | 03:56 AM
poweRX-7's Avatar
make sure it isn't the coolant sensor... that's what mine was
Old Aug 15, 2003 | 04:42 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Just drive around with a bunch of cups of water in the trunk.
Old Sep 29, 2003 | 08:52 PM
BigJim's Avatar
trainwreck
trunk... its funny when its referred to as a trunk, i call it a shelf, a big shelf, but a shelf
Old Oct 4, 2003 | 05:39 PM
MicahMan's Avatar
That's Nice!!!!
my 83 gsl has white smoke when i start it up. what does that mean? sometimes it smokes till it is warm.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
